turns out one of the braided lines split on the starter motor so oil pissed all over it, then caught fire and melted through clutch line and that kept going lol.. from what we can tell engine is fine, just gotta fix burnt wiring and replace what ever hoses/lines need replacing . hopefully done before domain HC!
Give me a yell if you need anything cobber, my old engine is still 99% complete so can rob it for spares :woot:
spotted: BOOST31 GTR being reborn, what a weekend
IT'S ALIVE!!! haha. thanks for the help buddy :woot:
now spotted is pretty much a whole other GTR in parts in my shed, better get snapping and start a for sale thread
spotted me having a bit of a shit fight with my turbo
i now have a new manifold-turbo gasket, 3 inch dump pipe and none of the rest of the exhaust :worship:
sounds awesome but i'll attach the rest of exhaust tmrw
can't wait to drive it with the new dump :)
the black r32 gtr with autocraft stickers is Jamie's, white one is P.J's, hes on the forum here somewhere :worship: not sure about other ones. burgz was in one doing limiter launches lol.
gotta love a limiter launch!!!!! also gotta love having a complete spare drive train in the workshop.....
Mine was the Grey 1 with white wheel's...
Wishing i had have spotted someone breaking into my 32 on sunday and stealing all the audio gear :starwars: luckily they couldn't quite get the car but snipped a few cables under the bonnet and played with the fuses! Little bogans need their hands chopped off!!
Saw a very race spec silver 32 gtr in melville st car park yesterday looked tough!!
Spotted our wagon with new slotted rotors allround along with new pads, thanks to me and Scotty. Also spotted pipster tonight lookn like his wagon has a big dent in RHS front door. Costly!!
Edited by skidkid
been there for a while now :)
just gonna get another door when i get back to qld, strip everything off it, paint it, put my plastic bits on and swap them over
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
