was a good day :-D very slippery first laps out and that wonderful comp lock up into T1 haha.
was good giving you a chase, would of chased a bit more but my car started playing up, think the diffs giving up on me lol.
yeah, next time. I was silly to go back out, brakes were not exsistant on the ride back! bloody hell those QFM pads are good tho, worked awesome down to the indicator! just orderd a new set + spare set.
yeah, my brake pedal is feeling a bit spongy now haha was good though, these simple EBC green pads have done 3 track days and 2 hillclimbs now, holding up well :-)
im quite surprised how well the R888's went!
spotted my 33 not ideling & seeming to fuel up at around 4500 5000 rpm doesn't do it all the time tho im thinking afm? maybe igniter? as it has almost new spitfire coils any ideas? running around 13psi
edit if i unplug afm idles fine as soon as i plug it in wont idle
Edited by Autumn_180
Check the AFM insidey bits where the bits actually solder onto the board, I've read it's a common problem for them to corrode and crack, the just need to be resoldered.
If you'd like a spare one to test I think I've got a spare one lying around because my R33 doesn't need one anymore.
Also my house mate is pretty handy with a soldering iron if does turn out your afm is broken.
How'd you go with your brake master cylinder problem?
brough a new working one fitted it but the pedal is still soft theres no air in the lines or anything the fronts work fine but its like theres no pressure getting to the rear brakes
That would be good i can grab the space saver on friday so if its ok we can test that at the same time?
yeah sure, send me a PM and tell me what time you want to come round.
Woah, I sold the space saver to an Autumn_180, not you Autumn33, imposter!
lol
Edited by zoidbergmerc
just a heads up. if you unplug the AFM the ECU will run in limp mode so it will idle and do everything normally. ive seen similar issues before but it doesnt nessasarly mean its AFM.
ill swap your 33 for my 4 door now if you want to. ;)
i found it will idle fine, but you try rev it and it will hunt and carry on like a spastic :)
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
