Hi all, thought id introduce myself as i've just acquired my second 33 :) its a black 93 S1, de-winged, completely stock bar a 3" cat back, aftermarket radiator and aftermarket brakes :)
hoping to have a few things done by the next SAU track day (when is it btw?) so i can have a crack! I will probably get spotted a bit as im out and about alot lol. hope to catch up with you guys sometime
Next SAU track day is kind of blended into one of the super sprints on 30th Oct, but I think a small mini tiny sneaky track day may be the go in September? At least I hope so 'cause I can't make the 30th :P
Interested to hear, what aftermarket brakes do you have on there?
Oh, and welcome!
pretty sure they're some sort of DBA slotted and drilled with sports pads, i wanna get an intercooler and oil cooler, and a replacement passanger rear strut (currently a little bent :() before i head out... or would it be fine with the stock cooler? and fixed strut obviously :P
I have an r33 with the stock intercooler and oil cooler (and pretty much everything else stock as well..). She's been running well with no issues for ~4 track days now, I'm just trying to take it easy and get the lines right though. My brakes and tyres overheat before anything else though, so It may be different with your set up :)
Oh, and welcome!
I m thinking a bit of sneaky practice would be the go too. theres not many free days at the end of september, maybe early september or early october...???
Agh yeah, the pads a really squeaky but are ment to be new, so I'm thinking they might be half decent ones?
Anyone have a stock series 1 coilpack they would like to donate to a fellow boat owner?? Hobart area :)
I've got a whole heap of rb coilpacks for sale off 2 motors i'm parting if you want a cheap one?
Early October sounds like a winner to me, I need to order in some new brake pads and get the rotors machined before I do any other kind of track work, as soon as they start to heat up and I brake heavily it feels like I'm driving over a never ending cattle grate :P
Will have to look into some specific dates for a sneaky practice
Yeah tweetywoof thats me, you say its a series one RB25 then yes they're exactly the same, RB25 series 2 don't use an igniter module on top of the motor and the series 2 coils have little modules on the top of each one that the normal ones dont..
Oh and just after $25 each
Edited by tobs_r32
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
