Tassie Spotto:
grandmasterb
spotto'd some great racing at basky this weekend.
also picked up my front LCA's I had Brad mod, looks awesome did a great job. much better that buying poxy chinese LCA's. very happy,l have full adjusment now top and bottom =D
some great racing, brad set a new record too, great stuff. good to see Leigh's car looking a bit more tamed now too after further tweaking, go the datsuns :thumbsup:
I too spotted Brad and Leigh today :D They're both looking amazing and doing us Datsun enthusiasts proud :)
Not sure if it's top secret or not but would you care to share pics of your new awesome LCAs?
Edit: Results from today herehttp://www.natsoft.c...17/09/2011.BASK
Edited by zoidbergmerc
Spotted Jack And Zoid,the Arms look the goods Jack.
It was a good weekend of racing. Well done to the Hobart sporting car club for a great meeting.
Brad took a clean sweap in GT A and I think if there was another lap in Boss of Baskerville he would of caught the leader.
Thats it for me this year, 4th gear didn't want to play the game and fuelling issues. So car will now get a make over for next year.
4th gear went cranky too? bugger.
let me know when your ready to off load your cage! and brakes... and and stuff lol
yeah that handicap race was great, but over handicapped Brad and Burns. good to see the skyline (gtst I might add) on top tho, crazy fast, say no too pushrods haha
:thumbsup:
spotted a mate of mine picking up the series 2 fronted series 1 stagea, think its the one that used to live down in hobart
im sure he will be around on here soon looking for parts and whatnot
also, my new stock rad is coming :D $220 delivered, can't beat that!
ha ha yeah david said he does uni with you
if its the add i saw on gumtree its had a bit done to it,
Well we go to the same uni, but I'm doing a real degree :P
Its got coilovers and a highflow and safc neo to run it all
Might have to get my act together and make mine faster now
ah k, yeah thought it had a bit more than that, but yeah still didnt look like a bad buy, but we'll see how his evo goes :blink:
ive seen your car outside dominos mobray a few times
oh, its got a trust front mount too, and one of those timing adjusters too
i'd expect it to make around 200kw on a dyno tho, haven't been in it yet
ah k my bro said it was your missus that works there :s
my bro drives the blue 180
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
