Detachable Penis isn't by Primus, it's by King Missile. Very good song but!
Oh well, R31 is gone now but my new daily is the Stagea.......could be worse!
Cheers, Greg.
P.S. Who's got the silver S1 Stagea on the Eastern Shore, I want your tow bar!
Cheers, Greg.
Oh so it is lol, Dunno how i buggered that up.
Cheers mate :(
Spotted SShatch in his r32 GTR going up Mount Street last night. Looked very nice and shiny :(
ahhh...
My first spotto.
I feel special.
I spottoed a heap of lines and other assorted imports in Launnie yesterday.
What I dont understand is that if you dont race them your a wanker, if you do your a hoon and if your just minding your own business trying to find a shop or park or something and thus going a bit slower than everybody else then your simply a nusciance to everybody else on the road...
You just cant win when you own an import.
At least with the Hatch people didnt seem to mind so much if you just crawled around at about 40kph.
ahhh...
My first spotto.
I feel special.
did u still need that part for the rear seat belt?
its still sitting at work.
Funny you should mention that...
I went looking for your number while I was in town yesterday but found that it was one of the many that didnt transfer across to the new phone I got a couple of weeks ago.
Have since found it again and will ring when I am coming through, as it will be soon.
Had a slight rattle in the top end, maybe lifters. Doesnt sound anything major. Plus there is power loss from the auto. Will lean on the boost to about 25psi when rattle fixed.
Comes on boost well for a dirty great turbo. lol
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
