Yeah for sure. Its a massive difference. The poor old 25 did a great job to make 399 a few years ago. Even more the 30 with the big turbo is still more responsive than the 25 with the twins.
And a 30 @ 8000rpm sounds tough.
Still havent turned on the gas yet, will only run the 50shot till i learn how to drive it then the 175shot will go in. :P
Spotto'd a certain green R32 coupe making one hell of a noise going through sandy bay. Looked good, sounded better :)
Hopefully Funz doesn't read this then, he will be devo to find out there is another green one getting around :)
Hopefully Funz doesn't read this then, he will be devo to find out there is another green one getting around :banana:
i knew there was a green r33 with black bonnet, and heard about another green r32, never seen it though :S , the GF has been driving my car around a lot lately especially down sandy bay way to the cas lol
Spotted a few 33's in and around Hobart on 23rd Jan., including what looked like a turquoise one?
Oh and a couple of 32's.
Nobody seems to have spotted my black 34 that day... which by the way I plan to sell or trade for a Forester (due to my new location :P
Spotted a fairly munted 32 GTR on the back of a tow truck at gowrie park on sunday, driver side door and A pillar looked like it had made contact with a rather large tree or pole or something. Was wrecking for parts but nothing really worth taking I didn't think?
  • 1 month later...
spotto
cops setting up for a lovled day in the sun
northboud on the tamar highway just after the bridge as you leave launie and just before the mowbray link
luckily for me cops dont like getting up early
spotted silver stag on high st bout 830 ish, only just though i was paying more att to the crane and all the other shit on the side of the road then where i
was going :D
Edited by Punk72
was going :ph34r:
that would me Matt :D very tidy stag, anyway spotted a black R34 in bathurst on Saturday nite about 9pm ?
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
