R33 400r Front Bar And Aftermarket Rear Bar
R34_T88_Widebody
 Share
actually....no....sorry.
Toff - the kit is about 3-4 minutes down the road from your yard.......or at least it was ( Shiners....)
Leigh - I assume you are up Nth? If so, I'll try to get photos, but don't hold your breath guys......
Leigh is in Hobart as well :down:
If Toff doesn't go to look at them i should be able to have a look and grab some pics for you J :(
Ben
OK - cheers Ben. I'll get Mick to have the kit available for viewing at Shiners by tomorrow.
I've actually just been told that the front bar is A1, but that the rear bar will need a little bit of TLC ( not because it is cracked, but because it is likely taken from a mold that has done too many replicas in its time). Therefore, buyer would need to factor in some extra prep time to get this fitted.
As a result, I'll do the front bar and the rear bar AND SIDE SKIRTS ( also aftermarket, and need TLC as above) for $475 for the lot. Just take em!!!
Rear Supra Veilside Wing - needs a fair bit of TLC due to splintering - $150.
Metal GT wing - $125.
  • 4 weeks later...
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
