What to know what brakes you guys/gals are using, im asking this b/c i need to get my brake pads changed. Been reading up on some topic concerning brakes on this forum and it is suggested that a majority uses bendix ultimates. Well, today I went to bridgestones and asked about skyline brake pads, turns out that they are hard to source, dont ask me why. Anyways, guy told me to go down to something brakes at keswick.
To cut a long story short, Ive got a choice between bendix ultimates and a brand called lucas. What i want to know is that who here is using lucas and who is using ultimates, btw brakes guy said that ultimates only came in the front and not the back. Also, diiference in price is quite large with lcaus half the price of ultimates, which comes in both front and back.
Suggestions and advice needed, thanks.
https://www.sau.com.au/forums/topic/15297-brakes/
Do a search on the net for a place called Race Brakes, they are in NSW i think. They have make all different pads to suit your car. Ultimates are OK, and would be a minimum quality but the ones I have are better, last longer and dont produce hardly any brake dust unlike ulitmates where you need to clean your wheels every week.
Skyline pads arnt hard to source, they are the same as a number of locally delivered models, you just cant get the cheap crap for them which you dont want anyway.
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-311658
man he is BSing u!!! the r33 brakes are the same as the r32gtr brakes ... i know cause i did this a couple of months ago .. i'm using ultimates too ... my stock mags are always dirty and ugly ... try to go green stuff if u can get it ... i run ultimates at the front and cheaper bendix at the back ... try to do it urself its pretty easy i heard cause i didn't do it myself LOL ahah ... anyways my cousin can help u out if u need help .. green stuff is about 180 i think for the front ... thats from autobarn ...
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-311713
what about lucas, anyone heard them/used them before?
$180 is quite expensive for front simply b/c i dont have that much money to spend, considering that its only half the component required too. :shake: just though ill like to add it, :alien:
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-311831
hey rob. saw you and your car on marion rd some time ago, nice shiny silver teeths. :P what brand are those race brakes of yours. in regards to dirty, i really dont mind dust unless in future it causes problems to the brakes and its associated parts. :alien: this green stuff, are there rear pads for them.
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-312004
Rob, my pads only make a small noise every now and then, do your disks need maching as this may make then squeel.
Ultimates are a pain if you like to keep your car looking ok, your wheels will be black in 2 weeks, i have heard som good and bad thing about green stuff, they are more expensive than the race brakes stuff as well.
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-312061
I run EBC Greens on the front (~$200+) & EBC Kevlars on the rear (~$90). Autobarn stock EBC. You can't actually get a Greenstuff rear pad for the R33/R32 range. I'm guessing R34 would be the same?
Combined with RBF600 Motul fluid they are bloody excellent in spirited road use. They produce some dust (very minimal), but they do squeal a tad, what decent performance pad doesn't? The EBC site claims 'zero squeal', most of the time they don't.
Read here - www.ebcbrakes.com.au
Greenstuff - http://www.ebcbrakes.com.au/green.htm
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-313756
  • 3 weeks later...
Ive had my brakes in for about a month now [bendix advance on both front and rears]. i purchased these as its cheap [pro] compared to ebc which i dont have money if i wanted anyways. my car doesnt have that much power atm so no need for ebc - its stock, any1 know there rwkw?. There seems to be little to no dust brakes that i have noticed therefore no need to clean mags that often. Its very responsive so braking is good and instant.
It does however squeel awfully in the mornings [con] - i assume because its very cold, but when warmed like other brake pads the squeel goes away slighly. What i found interesting however it that with my previous pads it didnt squeel no matter if it was very cold/cold or hot.
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-360016
But what is the perfomance of the pads like?? I can handle a bit of squeeling etc and a bit of dust really doesn't worry me im more interested in how long they take to fade etc etc.... I get my car back soon and i need a decent set so i can throw these one's in the bin....I was thinking bout endless or EBC redstuff....
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-361259
im gettin bendix ultimate put on right now first change i have done since i bought my car and getting the disc machined as they were pretty bad apparently, but everyone i called locally advised me to use them for everyday and can be used for track once in a while if i ever intend to go track racing which i doubt they were $89 a pair on special from www.justjap.com
https://www.sau.com.au/forums/topic/15297-brakes/#findComment-361351
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
