Just trying to get myself a roadworthy but the mechanic wont give it to me cause i get some sort of knocking sound from the rear which i think is from my Tein coilovers. I only hear the sound if i go over a ditch or something but not when im going on a smooth road.
My Tein coilovers have dampeners too and ive tried them on both soft and hard settings and i still get the same knocking sound. The knocking sound isnt very loud either.
So first of all is this sound normal for aftermarket suspension?
Does any1 get some sort of sound from their aftermarket suspension?
What is meant by "regassing" when it comes to coilovers?
https://www.sau.com.au/forums/topic/152981-noise-from-rear-suspension/
Not knowing what the knocking sounds like...I would try spraying the springs with WD40 first and see how that goes..if it fixes your noise and u get a roadworthy then great, otherwise my other guess is they're probably rooted and in need of a rebuild. Try the first option first coz it worked for me....
Do your strut tops have spherical bearings?
If they do, chances are they're worn out and that's what the knocking is.
Try taking your back seats out. Does the knocking get louder? When I had my old coilovers with spherical bearing tops the knocking got a lot louder with the back seats out, but with them in it wasn't too bad.
Edited by salad
ive been told that this is a common noise with adjustable coilovers, ive had my suspension checked out on Monday and they have reported NO problems
ive gone back to the mechanic this morning and persuaded him that the noise is a normal thing with TEIN's and so he gave me the RWC
im still gonna try the WD40 thing seeing as its worked with a few people and maybe it might help
Yeah I got the same problem with the one at the back of the passenger side, alot of people said it's a common thing with after market coilovers. The noise only comes out if driving on a hump or a ditch or something but it's gota be at a good speed too, and sounds like as if something is rubbing against something else.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
