Hey guys,
has anyone ever had a clicking sound at startup, that lasts for approx 2 sec and then stops. I'm thinking its got something to do with the starter motor - maybe the shaft needs lubrication or something? I'm worried it may need a complete overhaul?
Any of you guys ever had a similar thing happen?
Cheers
G
https://www.sau.com.au/forums/topic/1530-clicking-sound-at-startup/
I also get a weird sound, but it sounds like a different problem. Mine comes on after cranking it over and it has started. Sounds like something squeeking under the car, and I cant tell if it is coming from the front or the back! My only guess so far it that it is the fuel pump....
I have this sound when I start it first thing in the mornings.
I crank it, it starts, then you hear click click.
I 'think' I know how not to make the noise. This morning I was running mega low on fuel - on the E mark.
So I thought I'd let the fuel pump prime the system well before I started her up.
I put it in the 'ON' position for about 5 seconds until the fuel pump stopped priming, then started it up. And there wasn't any clicking noises !!!!
I have no idea what the clicking is, but try doing the above before you start her up.
Worth a try.
J
Wondering if it might not be a noisy lifter (RBs have hydraulic lifters, I think). Disappears because the oil pressure comes up to normal. Does it do it once the engine gets up to temp, say you stopped at the corner shop for something?
yer i have the same thing, a very faint clicking noise on idle, i have no idea what it is
I had a slight lifter noise when starting.
I began using a thinner oil (Mobil 1) and it has now stopped the lifter noise.
Also try doing an oil change after 2000km's with an oil filter and see if it helps - drop the oil while it is hot.
Then make sure you always do an oil change every 5000km's with an oil filter to prevent little gritty crappy bits getting in to the pump up hydraulic lifters.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
