Hi people, i got a r33 gts, and havin some dramas with it lately, when i give it a bit more gas, the engine stars kinda cutting off, and when i step on it all the way it doesnt have the power like it used to, and it only does this once the engine is hot, while its cold seems to be running fine, i just got the service done on it, and got new platinums, so its not the spark plugs, if anyone knows what could the problem be, please give me some insight, if the coils could be the problem i would appreciate it
P.S theres also a really funny smell coming out of it when the car's hot, dunno if that has anything to do with it,
https://www.sau.com.au/forums/topic/153025-could-coils-be-the-problem/
Did you wash the engine bay by any chance? I did it when i first got my car and i had the exact same problem. Also check out this thread its got heaps of useful info in it if your car is missfiring.
Good luck wit it dude.
http://www.skylinesaustralia.com/forums/in...howtopic=119403
are u giving a boot when cold?
or only when its warm..
yea i booted it, and seemed alrite although not as good as before, now i read that thread about siliconing the coils, so i took them out, firs 1 was fine but the rest had visible cracks and bluish color around them, so i spose that was the proble, i went to bunnings and got silicon, 2moro i'll put it all together and c how it goes, if it helps, i wanna say thanks to all of you for sharing this ideas and solutions with the rest, doing a great job guys.
thanks heaps for that i hope it helps since i pulled it all off, what i should have done in the first place and replaced the plugs myself.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
