I have just picked up a S14 R200 diff with viscous centre and have ordered the OEM nissan shims and plan on removing the current shims and installing 1.01 mm ones (factory ones are 0.80mm) There are 2 shims in the LSD and this will take the total preload up .42mm offering a tighter than factory viscous LSD. you can install 1 shim plus the 2 already there bringing the total up to 2.40mm but you will basically have a locked diff and are risking the spider gears binding.
The LSD cost me $100 and the shims about $10 each. and anything has to be better than an open wheeling diff. I am not expecting a mechanical 2 way or anything but will be happy with anything better than current.
The Diff I have in my car at the moment has a 4.3 ratio and the diff I have just bought has a 4.08 ratio. I don't really want to pull my old diff apart and am thinking of just using the 4.08 pinion and ring gear. How much difference will there be? between the 2 ratios? I have never really understood final drive ratios.
Also can you measure nissan diff ratios from the number of teeth on the ring gear? the one I have just got has 37 teeth. I would really like to confirm it's ratio is 4.08. Can anyone in the know about ratios please comment.
Thanks!
I will post up the results as soon as it is in. I am installing it on the weekend.
I have heard some really good results and will keep you all posted.
Not sure if this helps or not but this is the guide I used when I shimmed a diff a while ago
http://www.d1nz.org.nz/forum/viewtopic.php...a84e160bbe32105
There was only 1 factory preload shim in mine though (R32).
Here' a list of shims + prices that I found from another thread.
0.80mm = 3842440f60 price = $10.12
0.85mm = 3842440f62 price = $14.67
0.90mm = 3842440f63 price = $9.97
1.01mm = 3842440f67 price = $9.79
1.05mm = 3842440f68 price = $14.40
1.10mm = 3842440f70 price = $6.37
1.20mm = 3842440f73 price = $6.37
1.30mm = 3842440f76 price = $10.89
1.40mm = 3842440f80 price = $6.37
1.49mm = 3842440f83 price = $6.37
For a tight VLSD that's not locked, I would personally got 1.2 or 1.3mm shim without the stock shim. But I dont know, I havn't tried personally, just a guess. The one I shimmed up was for a guy that wanted it locked, so I put in a 1.49mm + the stock 0.8mm.
Using the different final drive will put your speedo out as the speedo reads off the gearbox and assumes a final drive rato. If you've got the whole diff, count the number of teeth on crown and divide by the number on the pinion.
You will have 5% less acceleration but 5% higher top speed.
Edited by salad
Thanks Salad,
yep. I have pulled the centre apart and found there to be 2 preload washers
1 on the onderside of the viscous centre and one on the other sode of the spider gears carrier ( opposite ends of the housing)
I found that when I put the second shim in the whole assembly would not screw down completly leaving a 1mm gap between the 2 halfs of the pumpkin.
Did you find the same thing?
CEF11E,
Could you count the spline on your half shafts (that slide in to the viscous hub)
I have a good tight VLSD Q45 Infinity viscous hub here that I'm toying with throwing in to mine for a quick fix.
Long story short I picked up what was supposed to be a GTR diff and axles, turned out to be GTR axles but with a Q45 Infinity vlsd centre and half shafts.
The Q45 Infinity runs the same half shaft/axle 6 bolt (1x6) pattern as the GTR. Unable to tell the difference until you rip the back cover off and notice its a VLSD unit. :P
I had a hell of a time trying to get the unit back in to the housing. :S
Let me guess? blocks of wood and a hammer?
sure will count the 1/2 shaft splines today for you.
The diff I am using is a S14diff with 3x2 halfshafts so I am not sure it will be the same.
It will be fine. The 3x2 halfshafts are interchangeable with the 1x5 halfshafts. :D
yes Blocks of wood and a mini sledge hammer. :P
Thanks Salad,
I dont remember one being on the other side of the spider gears carrier, although it may have been stuck to the housing?
There was a gap when I slid the 2 parts back together, but once the screws were tightened the gaps were pretty much gone.
Hows the VLSD you shimmed holding up?
I was actually just trying to sell my old VLSD centre so I just shimmed it to sell it. Sold it to a guy on NS.com and havn't heard back from him since, so I assume it's still goin. :pwned: I can get onto him and ask him how it's goin if you want?
I shimmed it the same way as a couple of my mates did aswell, and theirs are still going after over a year of track and daily driving.
Edited by salad
Yeah, left the stock ones and added one.
I didn't realise there was one on top of the spider gears though. Guess it makes sense that there would be one there. Must've been stuck to the housing so I didn't see it.
I was mainly going off the guide I posted earlier. It said if I wanted it very solid, put 2 extra stock shims in, so extra 1.6mm, I put in an extra 1.49mm, close enough.
Edited by salad
I am still deciding what level of shimming to use.
I bought 2 1.01 shims and think I will use one of those either side. I am not after a locked diff and the centre will not screw together with 3 shims in it there is a 1mm gap.
I can not turn the centre at all by hand using the 1/2 shafts with the 2 1.1mm shims in so i presume it will be fairly tight.
I put in a 1.2mm + the std 0.8mm shim in mine and i hated for the first few weeks, as it felt like i was driving a train when turning corners with a constant "clanking" sound.
A couple of months later sound and locked feeling has worn off and still not open wheeling... Plus the car feels so much more predictable... it reminds me of when i first got the car with 64K Km on it....
Mistake i made when assembling it together was not putting in shafts before tightening crown, as splines did not line up and hence shafts would not go in all the way...
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
