GT30 will slot in just, GT35 would be more ideal though.
The T04z is bigger than the GT35 again, miles above what you need :D
Although you better pray to the gods that motor lasts at those kinda levels as if your gonna circuit it, it wont last forever unfortunately
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2847204
you know DVS32R...lots of people say that about big turbos. Not to be negative or rude, but its not always like that when your racing. On some tracks its almost impossible to maintain high revs to keep on boost. And once you fall outta that powerband for a split second...by god it feels like almost half the field just passed you.
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2851697
GT35R would be more suitable for 500's, but I hope you're going to add a full engine rebuild to that list for those power levels. Try not to get so hung up on a particular hp number, but rather go with what feels best when driving in real world situations. Alot of times, less power can be faster if that makes any sense.
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2851932
i agree with that too, ive had no experience with curcuit yet, lag is heaps annoying, its good for dynos and winning comps etc,
reason for my comment is my neighbour races his mini(yes totally different) and is always in the high revs, probably due to gearing etc
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2851935
yeh...if you could afford gearbox and diffs to change ratios around so you could have say six gears and the ratios were tailored to suit your setup and the tracks you mainly race on...that could help...so your in the right gear and in the power band pretty well all the time...like i said before...one corner were say 2nd is too high and wheelspin is an issue and 3rd just bogs down and drops you outta powerzone...what do you do? Personally I wish more money was available.
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2851940
I agree , with the cost of close spaced gear sets and final drives these days most find it easier to make the engines power characteristics suit the available gearing .
The GT3582R is probably going to cover what you want to do but cam selection and headwork will make changes to its power delivery . The secret would be making lots of mid range torque and not having it start at 5500 revs . Most people developing engines to do this use cam profiles with a fair bit of lift but not the extended valve open period (extended duration) . Cams like this don't need to bet set up with a lot of overlap which turbo engines don't tend to like if they have a restrictive exhaust side because they get reversion . If you can uncork the exhaust side and run high octane fuels the static CR could probably stand to come up a bit from 8.5:1 . Depends on budget I suppose .
Cheers A .
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2852036
Cheers A .
Problem is as lift increases generally so does duration. Yes you can increase lift without increasing duration to a point but then ramp angles are effected so greatly it cause valve train issues and any self respecting cam grinder wouldn't do it (after the practical max lift has been reached).
Another option is to run the longer duration cam but advance the intake and retard the exhaust, this can be used to offset a bit of the increase in overlap.
Edited by AWD2Go
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2853628
I'm talking about the sorts of cams commonly available in the aftermarket - 26 something by 10 odd mm lift . If he wants to keep the state of tune of the engine suitable for std gearbox/diff ratios long periods cams may make it peaky . Falling off the cams is no better than falling off the boost threshold . The burning question is what useful power range and starting where .
Cheers A .
https://www.sau.com.au/forums/topic/153046-gt3040-vs-t04z/#findComment-2853804
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
