Although one been more accurate than the other, could someone refer to me why they are extremely different in values?? and what would xxx amount in dynologic refer to yyy amount in dyno dynamics shoot6f
Cheers guys
Adam
https://www.sau.com.au/forums/topic/153057-dynodynamics-vs-dynologic/
Cheers guys
Adam
Its the dyno operator...we tune at Croydon Racing in Sydney (dynodynamics) ...and at Autosalon (dynolog)the next day made 1kw less power. Both these dyno are ran by very skilled operators...hence the accurate power readings.
  • 9 months later...
Having owned and used both the Dynologic and Mainline Dynos, as well as used countless other dynos, I would have to rate the DynoLog Software (common to both DynoLogic & Mainline) the best I have ever used. The software, data logging, speed control (even tacho based speed control for autos), makes DynoLog hands down FTW.
DynoLog software, originally designed as cutting edge engine dyno software, has been modified to run as a chassis dyno. With as many inputs as you could possibly imagine, and data analysis that would satisfy the most data hungry scientist.
The differences in all the power outputs come down to a few factors, the main being atmospheric compensation (mainly AT on DD). Dyno Log dynos use their own discreet weather station, constantly sampling atmospheric pressure, temperature, and humidity. Dyno Dynamics dynos sample air temp from the probe, which is placed under the bonnet or other high them areas by some operators, hence 'inflating' dyno figures. Atmospheric pressure and humidity are a 'user' input, and are certainly not updated automatically, let alone real time.
One other major variation is the SAE standards used to calculate atmospheric correction. The older standard J607 is still found to be used on many dynos, and in general can read around 3-10% higher that the newer SAE standard J1349, which is what is used by most newer DynoLog dynos, and also on the Mainline/DynoLogic dynos used for the AutoSalon series.
That I think, is the difference in Dyno Dynamics (dyno for mechanics) and Mainline/Dyno Logic (dyno for technicians) Dynos.
Apart from the above atmospheric corrections, there are other 'intentional cheating' methods employed by less honest, or less educated, dyno operators, such as roller intertia values, and other rudimentary calculations...
If anyone would like to discuss my opinions, or needs some contacts with either Mainline or Dyno Logic, please do not hesitate to call.
Sam.
0425 818 755
Edited by Dr_Drift
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
