  • Replies 103
The stupid thing is, my 60foot time was 2.4 (which is crap, but getting better its usually around 2.5) and my quickest terminal speed was 104.5mph so thats up as well... I just cant seem to get from 0-400 any quicker today than 14.18 *shrug* I give up. Should just buy a GTR and be done with it.
Ok, my best terminal speed was 104.52mph that run was:
60' 3.003 sec (wheelspin, didnt grab too well)
330' 6.899 sec
660' 9.943 sec
1000' 12.516 sec
ET 14.680 sec @ 104.52mph
funnily enough I ran a 14.698 with a terminal speed of 89.82mph, 60' time of 2.561, so I'm beginning to wonder if terminal speed really means diddly squat. My best 60' time was 2.422 that run:
60' 2.422 sec (bit of wheelspin)
330' 6.234 sec
660' 9.322 sec
1000' 11.945
ET 14.158 @ 102.27mph
All my launches were done at 2000-2500 revs and dropping the clutch, I think I had about 1/2 throttle on but I cant remember, everytime I bogged down or wheelspun. I know my pineapples are lose cos they have been making ratteling noises, the workshop wouldnt over-tighten them so they've come loose again. Next time I am gonna insist they overtighten them. But my problem lies in the fact I cant get the car to hookup right with no wheelspin or not bog down. I've got 225/50 dunlop sp9000's on the rear wth around 20psi in the back, the only thing I didnt do was a burnout, but I dont really think it would have helped. Any idea's guys cos I'm getting pissed off spending $30 and not getting the times the car is capable of.
rob - i got my best results with a 3000rpm launch - but it did bog down a bit..
hmm me confused.. the car sounds like it should do alot better.. do you need to work on your gear changes? hows the 1st-2nd change? you can loose quite a bit of momentum if that change isn't quick...
My gear changes are good, its the launch that is letting me down I feel. I was only there for 30 minutes cos the missus rang me and apparently my mother in law was a bit upset I wasnt going to be there for lunch, so at 12:30 I sped back home. There was **** all people there, so I reckon its the best time to go, in 30 minutes I got 5 runs, thats better than any wednesday night session and it takes 2-3 hrs to get that many runs.
Yeah, have it balanced on the friction point, and just use the handbrake to stop you moving forward. Then when the last orange is about to go, drop the hand brake and the car will ease off the line, no wheelspin or axle tramp.
See'ya:burnout:
Originally posted by Steve-SST
Gavs GTR did 12.6 with 277rwhp. Did yor boost stay up?could
try Turbo Viagra. Street meets have the start beams moved back
1.6m to look after the race line so your doing about 2.0s and
13.7-8s on the real 1/4 1.6m at the start is heaps.
1.6m at the start is the same as 1.6m at the end, and would make bugger all difference to the 1/4 time.
At 104mph, or 46m/sec, 1.6m extra track would add an extra 0.035s .... which at 14.18s would give you 14.14s quarter mile.
:uh-huh:
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
