To summarise--------------
Genarally speaking, it all depends on the motor model as to whether adjustable cam wheel/s are worth it with poncams. And I don't know if the same holds true for other cams such as HKS etc.
With poncams installed:
I've heard that RB20's still get some benefit out of trimming the timing.
RB25's generally get very little benefit.
RB25 NEO's Don't know, don't remember, somebody else???
RB26's get good benefit with cams, and because they don't have NVCS variable valve timing on the inlet side they can use an adjustable cam pulley on both inlet and exhaust.
That should keep everyone happy [except GTT owners until someone verifies].
tridentt150v- what other supporting mods do you need for poncams?
Other than the usual fmic, exhaust, power fc..
Thats a good start, You'll get good power out of that combo. Throw in a bigger turbo at some stage as well.
GTR & GTS-t are different in the gains from cam gears
GTR's, there is a massive gain if you keep the stock cams
GTS-t's, sometimes there is no gain at all.
i wonder the reason behind it?
i have them on mine, with pfc and i gained about 60hps at the wheels
So would you guys recomenend getting my exhaust side pulley tuned if its already on the car. Or is it not worth my while. I have done all the usual bolt on mods?
There is no yes/no answer. You will have to book some dyno time and do a few runs while adjusting the timing to see what gains you will get. Some gtst's don't benefit, while others get real gains at up to 5 degrees. For me it was best at 4 degrees. The gain was only 8kw over 0 degrees. And I had fmic, zorst, pod, pfc, etc etc.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
