Just wondering if someone can post up some links to where you would find one of these. Its for my gts25t and hoping to spend around the 200 dollar mark to get one. oh yeah needs to line up to the standard airbox too.
Cheers Brett.
Hey Brett, the justsr metal intakes for rb25 wont fit the stock airbox or even the aftermarket pod filter box that u can buy off these forums. Im going to see a steel fabrication place about making me a pipe that will let me use a aftermarket airbox for the pod.
Edited by tmc_2
i've been after 1 myself but they cost to much between $170-$300. So now i have a friends rubber intake pipe (R33) and im gona buy sum 45 degree stainless bends and a stainless reducer and weld it up myself. Bit of stuffing around if i make it good i might make a few more n start selling them.
stainless is mainly better on non-stock turbos as they suck in alot more air, but if its nessessary for stock air box best to get one custom fabricated, to suit your needs , and yess for that it will cost the dosh to do,
hope that helps
I was thinking the same thing. 170 seems a bit much if that does not include postage. probably make it myself a bit cheaper.
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
