  • Replies 121
hey mate i am interested in the apexi fmic kit. how much do you want for it? can pick up as well. i might even get the injectors as well but will see how the founds go this week, let us know
cheers
cheers
pm sent
Ok guys sold the Apexi Cooler.
I still have:
GT3071R Turbo Kit. $2500
SARD 550cc injector Kit (NEW) $700
OR BOTH FOR $3000
BOSCH 040 $200
TEIN COILOVERS $800 0N0
APEXI TIMER $50
CHEERS,
BILL
I still have:
OR BOTH FOR $3000
BOSCH 040 $190
TEIN COILOVERS $700 0N0
APEXI TIMER $50
CHEERS,
BILL
ATTENTION ALL PRICES HAVE BEEN SLASHED!!!!
Here are some parts I am selling:
1. GARRETT GT3071R 500HP TURBO KIT 1.5months old has 10months warranty from GARRETT
exhaust a/r 0.71, compressor cover a/r 0.5.....made 237kw on stock boost on the standard fuel system,
(comes with 4inch intake from comp cover to AFM and mates with standard BOV position, teflon braided oil and water lines and custom turbo elbow to cooler piping, adjustable w/g actuator,4inch silicon for comp cover and 2inch silcon for turbo elbow, adapter plate...with lots of reciepts) cost me nearly $4000
$2500*
7. TEIN adjustable coilovers suspension set (adjustable height/rebound/compression) great for circuit or drift - $800
8. Bosch 040 500hp intank with new fuel lines (ready for direct replacement) 1month old - $200
9. R33 S2 10/97' OEM Fuel Pump - $90
10. 6 SARD 550cc injectors Brand New - $790
11. JVC CD Stacker 12 disc - $100
12. APEX turbo timer - $50
13. Mickey Thompson Street Radials 2 brand new (275/40/R17) - $490
FITTING IS AVAILBALE IN MELBOURNE FOR A NEGOTIABLE PRICE
AS A PACKAGE - turbo & injectors- $3000
No stupid offers please.
HEY ANY PICS OF THE TURBO TIMER? pm ME WID THEM PLZ
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
