Fs: [sa] Drift-r's 18s With 80% Tyres Left $900 Lots Of Dish!
After getting dicked around the rims are back for sale
Selling a set of 18inch Drift-R's that are 8.5 inchs wide. They have 80% Tred on 3 tyres and one has done about 2000ks so still almost brand new. 3 tyres are Nankang 225/40/18 (the 80%) and the other is a ANTYRE 225/40/18 (NEW) They are still on the car if you would like to have a look! The center is painted white, could do with another paint job if your fussy. Few slight gutter rash! first to see will buy..
Feel free to ask any questions
PRICE DROP NOW $900
Edited by Lennos
PRICE DROP NOW $900
can you pls advise
where you are
offset
width of the rim (18x8) (18.8.5) (18x9)
Also - does anyone know how difficult it is to get these repainted and where ?
I'm in Brisbane
I said they are 18x8.5
unsure on the offset but was told GTR off set, (Fitted no problems on my R33) and also said im in SA
can you pls advise
where you are
offset
I'm in Brisbane
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
