ok well there is the first problem
if the boost display isnt correct then you have very little hope of controlling it correctly, other than guesstimation. what is the part no# on the map sensor?
it sounds like you may have a different rated map sensor
Paul
I will look tonight, but if i remember i couldnt locate the part number. I'll check. When i initially hooked it up, i had no problems, at least i could control boost so that part doesnt particularly worry me.
It does come with the kit, i got my kit 2nd hand with my PFC and it didnt come with it
Ahhh i thought so, thanks for clearing that up,also does the power fc boost controll solenoid plug straight into the gts25t standard boost controll solenoid wiring loom?
Cheers mate
Cheers mate
no you have to cut and solder.
maybe back the front?
Tried reversing the NO line, wastegate didnt even open so plumbed it back.
I guess its the solenoid
Hey,
edit: strangeness! if you connected to the other port, you should have had exact reversal of previous
behaviour - with BCK enabled, should have been running on spring pressure; with it disabled, should
have been "unlimited" boost. Anyway...
At least you're making progress :)
Put a multimeter that can measure duty-cycle on the solenoid, and see whether it's being told to open or not.
At this point it doesn't _sound_ like the solenoid to me - when you have it enabled, it's closed; and when you have
it disabled, it's open. Sounds like the solenoid's working fine, but the controller's not telling it to open ... the
meter will tell you for sure though.
Regards,
Saliya
Edited by saliya
Hey,
At least you're making progress :glare:
Regards,
Saliya
Thats what i am thinking , the controller isnt telling the solenoid to open, coz the solenoid is opening. Also, something i noticed on my controller, Settings, Boost, no.2 the last digits are 201 instead of 255, all the rest are 255. Is this normal??
Cheers
Cheers
Pretty sure that's the "learning" part; _exactly_ what the number means I don't know; but when you change
the duty cycle it goes to 255 again. A number that's not 255 is perfectly normal as far as I know.
If I had to guess I'd say it's "attack" - and that it self-adjusts so that you approach target boost as fast as
possible without hitting the boost cut - but I don't know :P
Regards,
Saliya
i just dont see how the boost control kit would work if the boost reading youve set to be desired and duty control, but the boost control the PFC is seeing is way off
like if you set the target boost to be 1.2bar at 80 duty cycle thats fine
but if the map sensor signal is wacko and it only ever see's say 0.30bar cos its wrong, then it has little hope of working, or at least i dont see how?
Hey,
if the MAP sensor's reading 0.5kg/cm2 and you set target to 0.5 (and it's _really_ 'something else') don't see how that would
be a problem - after all, it doesn't really care _what_ the number is, only how close to (or far away) you are from it...
I'm pretty sure he's "aiming" at the sensor reading (like if the sensor reads 0.5, but that's really 1, and he really wants 1, then
he programs 0.5...)
The only time this would be a problem that I can see is in terms of resolution (like if 0.1 == 1, then an 0.2 overboost is actually
3 instead of 1.2); or in terms of minimums (say it reads 0.3 @ 1; you can't dial up 0.3 as a target if you want 1)
Regards,
Saliya
Hey,
he programs 0.5...)
Regards,
Saliya
Saliya
Exactly, previously i was able to set my boost aruond the wrong reading and didnt particularly worry me.
Well ive given up, the solenoid has power there, i cant hear it move, so i am thinking it maybe my PFC which cannot adjust anything to it. Going to get rid of it and try a cheap boost valve.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
