I posted this over at gtr.co.uk, but haven't got any responses really, maybe you guys can help me out...
I have been searching for info on this for a while now. I would truly like to buy a GT4088R and be done with it, but right now money is tight and I'm not sure I can afford a ball bearing turbo when the time comes.
So what I am looking for is anyone's input on spool time for decently sized journal bearing turbos on a stock displacement motor with stock heads. My goals are between 550-600 whp. I have a pretty good knowledge of turbos and choosing the right turbo, but some first hand RB26 specific info would be great. Specifically these are the turbos that I am looking at mostly...but if anyone has any other suggestions definitely don't hesitate to voice you're opinion. Some specs were hard to find.
Also I must state, that this will be in a LHD Z33 and I really do not want to deal with the hassle of twin turbos and downpipe routing around the steering shaft, so twins are pretty much out. My hp goals are in the 550-600 whp on pump gas. The motor has CP pistons and stock rods with arp rod bolts...fyi.
Garrett TO4R
compressor: TO4S
.70 a/r
66.5mm inducer
84 trim
flow: 75 lbs/min 960cfm
360* thrust bearing standard
turbine: T4
.96a/r divided
P trim wheel
360* thrust bearing
wet center section
Garret GT4088
compressor
.72 A/R
88mm 54 trim
turbine: T4
1.06 A/R Divided
77mm 84 trim
PT66
Compressor:
66mm inducer
52 trim
Turbine: T4
.96 A/R Divided
P-Trim Wheel
76 Trim
360* Race bearing
We reparied and highflowed a HKS T04S on a Tommy Kiara R33 GTR
All the important bits putting out 685rwhp hitting 1.5 bar at just after 5000rpm.
This is with HKS 272 degree inlet and exhast cam shafts on a near standard displacement engine (2.645) 87mm pistons built at Signal in Japan.
Most big horsepower singles are Journal :laugh:
I would have thought a ball bearing TO4Z would not be the end of the world these days depending where you got it from . If you know someone who can strip BB turbos a cheap way to build a TO4Z is to buy a Garrett T3/T4R , one of them is a TO4 P trim/60-1 hybrid (cartridge or CHRA no 757179-0001) and that compressor can be flicked for the TO4R compressor that TO4Z turbos use . Some machine work is required because often bush bearing compressors use different back spacing to ball bearing ones .
HKS's TO4R is just the same P trim turbine /TO4R compressor with a slightly cropped turbine in bush bearings .
The part nos for the wheel , housing and backplate are 451470-0001 , 409722-0023 , and 408997-0018 in bush bearing TO4S outline form - according to my data . It shows the wheel as BCI-8D family .
Cheers A .
So any other experiences with spoolup time and journal bearing turbo's like these?
discopotato: Is that to make a T3 based TO4Z?...because my manifold will be T4 divided.
Edited by 002-M-P
plain journal GT4088 1.34 rear housing on my stock headed 25/30 was on full boost around 4500 in 2nd gear, earlier in higher gears. they're a good thing i reckon with a smaller exhaust housing than mine. they have a HUGE compressor cover so watch your clearance to the strut tower etc. TA45 split pulse flange on em i believe.
TO4Z's are really easy with turbine housings , ANY TO4 P trim turbine housing bolts up to them in a myriad of A/R sizes , and single/split T3 flange or single/split T4 flange or single/split TA45 flange which is sometimes called T4 International . The only thing to watch using Diesel spec turbine housings is that they sometimes develop cracks over time because the material spec was intended for the Diesel engines lower exhaust gas temperatures .
Garretts GT40 range of bush bearing turbos are more modern designs than their TO4S and TA 45 ranges . Better cartridge and wheel technology though not right up with the BB GT4088R . This ones a ball tearer depending on the airflow required and even has the high temp spec turbine and housings for petrol performance apps . The down side is a retail price of someting like $2750 . With our rising dollar and sales competition it may get better .
Cheers A .
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
