Hi everyone,
Not sure if I have posted in the right thread. Will be moving to Melbourne by next month. Looking out for a R33 Skyline Series II Non turbo (25 GTS or 25 GTS4) as my daily drive. Would like to know:
A) Whats the price range like?
b) Cost of Maintainence?
c) Cost of insurance?
Anything else I should be on the look out before making my purchase?
Thank you :laugh:
Edited by ewhs
https://www.sau.com.au/forums/topic/153104-need-help-on-r33-skyline-gts/
Pricing - cheap. around 10-12k will have you a N/A R33 i would imagine.
Would make for a good first good car or similar actually.
Maint - usual servicing, 10,000km's i think.
So maybe a few hundred
Insurance - totally dependant on your rating, prior history, car type/model and location you live.
So its impossible for anyone to give you an idea on that
Other than that, nothing.
Read the DIY thread:
http://www.skylinesaustralia.com/forums/in...showtopic=35129
It will cover more detailed things for you.
cheers
  ewhs said:
Hi everyone,
Thank you :P
As nismoid said.
A) 10-12 K.
B) Cheaper for NA. Change oil every 10,000 KM. you could probably do it yourself.
C) NA insurance would not be much IMO but as nismoid said, depending on your age, location and driving history.
R33 S2 is a great car... I own a turbo one. Love it!
THank you Nismoid and CCCP for answering my queries.
Im from out of town and not sure about the Insurance Premium for a Skyline.
CCCP, Actually Im thinking of getting a Turbo R33 but the prospects of having high maintenance costs
is putting me off. Besides, I understand that being a Probationary driver in Victoria, I cant drive a Turbocharged vehicle?
Regards
  CCCP said:
As nismoid said.
A) 10-12 K.
Regards
Yep no r33 gtst 4 P platers im pretty sure u can drive the 32gtst though my r33gts whilst i was on my Ps full comp insurance with just cars was round $950 i think 3rd party f&t was bout $550 which aint all that bad i spose but its the excess that get you as youra male under 23 drive a skyline plus the normal excess i think its bout $2000 or so if the car gets stolen
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
