  • Replies 150
Posted Images
Troy - I'd do it, but i'm to scared of your car, it just randomly spins for no reason!
The reason is the tool behind the wheel was doing a whole number of things wrong. From driving a car with bad suspension too hard, too not paying more attention to overfilling the gearbox, not paying someone like Racepace to maintain the car... to well just driving like a tool. Thats what the carrot of a 1:22 at Sandown does to me. Imagine how much trouble i have when a shiela gets her kit off in front of me.... I'm way too exceitable :closedeyes:
James isn't allowed to punt the Aston hard or else he'll get fired.... Still - there's worse things in the world than being paid to drive an Aston around for 3 days even if you can't drive it 10/10th.
There is a new "Teams" competition this year and I think we'll have to form Team Racepace in Vic :(
Is this the V8 Vantage owned by a Tassie dentist that was in Targa Tas this year? Or could it be the DB9R recently imported for Nations Cup?
Both sweeeeet sounding Motor Cars sir!
Well i'd be perfect, i never drive 10/10th.... :D
What's with the "teams' competition? Team racepace FTW!
Very true mate, and that's how I originally was going to go but I began to worry about all these SR's and how old they were getting and thought it may not be as easy as that in the coming years, so I went the new engine route. A 1:21 will be awesome for a gts-t, let alone a standard engined one!
Well after day 1 James Ward leads Class A for co-drivers and finds himself 4th outright on handicap points. Not bad for a hack.
And as expected giants R32 GT-R is slaughtering the field in the main competition.
If he gets a trophy on merit! Be pretty cool. But the NSW rally must be pretty weak if a pampered Supercar is allowing him to come 4th outright
Wooh - trophy on merit! Trophy on merit! :wub:
The Aston did a great job all weekend. Never missed a beat and looked and sounded great every day.
I won Class A co-driver and came 4th co-driver outright handicap (I can handle being beaten by Russ, a GT2 and a Carrera RS).
Great event - Eastern Creek Sunday was a standout - and as always, great people involved.
Car is filthy and I'm knackered.
Time to put a report together for the boss...
Congrats to Mark and Russ on another awesome performance. GT-R's finishing 1st and 3rd as well. Not bad for cars designed in the 80's. Although I still can't believe Mark got beaten at all the track events. That GT2 must have been awesome with a handy driver to boot.
And well done to the Hack King James for winning his class in the Aston Martin. It seems this last 6 months of motorsport has turned you into a bit of a driver.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
