  • Replies 150
Posted Images
Troy - I'd do it, but i'm to scared of your car, it just randomly spins for no reason!
The reason is the tool behind the wheel was doing a whole number of things wrong. From driving a car with bad suspension too hard, too not paying more attention to overfilling the gearbox, not paying someone like Racepace to maintain the car... to well just driving like a tool. Thats what the carrot of a 1:22 at Sandown does to me. Imagine how much trouble i have when a shiela gets her kit off in front of me.... I'm way too exceitable :closedeyes:
James isn't allowed to punt the Aston hard or else he'll get fired.... Still - there's worse things in the world than being paid to drive an Aston around for 3 days even if you can't drive it 10/10th.
There is a new "Teams" competition this year and I think we'll have to form Team Racepace in Vic :(
Is this the V8 Vantage owned by a Tassie dentist that was in Targa Tas this year? Or could it be the DB9R recently imported for Nations Cup?
Both sweeeeet sounding Motor Cars sir!
Well i'd be perfect, i never drive 10/10th.... :D
What's with the "teams' competition? Team racepace FTW!
Very true mate, and that's how I originally was going to go but I began to worry about all these SR's and how old they were getting and thought it may not be as easy as that in the coming years, so I went the new engine route. A 1:21 will be awesome for a gts-t, let alone a standard engined one!
Well after day 1 James Ward leads Class A for co-drivers and finds himself 4th outright on handicap points. Not bad for a hack.
And as expected giants R32 GT-R is slaughtering the field in the main competition.
If he gets a trophy on merit! Be pretty cool. But the NSW rally must be pretty weak if a pampered Supercar is allowing him to come 4th outright
Wooh - trophy on merit! Trophy on merit! :wub:
The Aston did a great job all weekend. Never missed a beat and looked and sounded great every day.
I won Class A co-driver and came 4th co-driver outright handicap (I can handle being beaten by Russ, a GT2 and a Carrera RS).
Great event - Eastern Creek Sunday was a standout - and as always, great people involved.
Car is filthy and I'm knackered.
Time to put a report together for the boss...
Congrats to Mark and Russ on another awesome performance. GT-R's finishing 1st and 3rd as well. Not bad for cars designed in the 80's. Although I still can't believe Mark got beaten at all the track events. That GT2 must have been awesome with a handy driver to boot.
And well done to the Hack King James for winning his class in the Aston Martin. It seems this last 6 months of motorsport has turned you into a bit of a driver.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
