Hi guys,
Almost at my wits end trying to rectify my boost problems now. What i need is someone who has installed a AVCR boost controller (or similar - i have instructions now - woohoo!) and a few hours of thier time over the weekend. I'll shout a carton of their choice for the favour.
Basically for those who don't know, my car had an exhaust leak in december, i had that rectified by the awesome guys down at Belconnen Discount Tyre Service (Marc2 and co), however since i've had it back, its suffering a severe lack of boost problem.
Mechanically its fine - purr's like a kitten, no misfires, clean airfilter etc etc etc.
I have a feeling that something to do with the AVCR isn't hooked up properly. Jayce put me onto Glen at ESP however he can't get to look at the thing till after monday. Glen mentioned that the most common thing that goes on is that people don't hook up the Comm point on the Apexi solenoid to the Turbo's Actuator. I'm going to be honest here and say, i have nfi where the actuator is :P
Failing that if someone could go through the install with me to check its all where it should be, and hopefully all the problems go away.
So yeah, if anyone can help me, throw a reply here and i'll pm you my mobile number :P
Thanks in advance guys.
https://www.sau.com.au/forums/topic/153140-need-a-favour/
This might sound silly, but have you checked your cat at all? I found that mine had the insides collapse into this awesome mess of cloggingness which stuffed my boost right up. New cat and off I went though - might be worth a look.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2848796
no rattles or anything that would suggest it. Not to mention the fact it would have to be hideously coincidental.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2848973
The actuator is the round half beer can shaped goldie coloured metal canister just above your turbo {I'll try to find a pic and show you}. It has an arm coming out the back of it that controls your wastegate.
What Glen means is that your AVCR is your boost controller and its not get the boost readings. In the engine bay there should be a part of the AVCR that has little 6mm rubber hoses coming out of it. One of these hoses will be hanging loose, you need to plug it back into your actuator. It will have a nipple coming off it for a hose to push over.
Atm your AVCR is not reading boost, it is reading atmosphere.
Of cause this is only any good to you if that is the problem, and I don't know why Glen did not fix it for you on the spot, it is a 30 second job.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2848999
Glen was on the phone, he's out of town till monday.
What i've got is
2 hoses out of the Apexi Solenoid going to their proper places (so i'm told - which is why i'd like to check), can't remember anything else coming out of them.
However i do have the standard solenoid there, but the hose out of it is blocked off with a screw.
i'll try and take pictures tonight and show.
The AVCR is reading boost (as well as the standard boost gauge) it just slams at 0.55 kg/mm rather than heading all the way up to 0.8 like the controller is set to allow it to.
I have SOME boost, just nowhere near what i should and what its set to. What will the wastegate do on its own?
Edited by nsanity
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2849017
Nothing,
1. It is prob. not getting enough boost to open.
2. It is driven by the actuator which is getting no signal [maybe if hose is missing?].
Where was your exhaust leak? Did they play around with the turbo/manifold/dump pipe area - which one?
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2849880
Nothing,
3 headstubs and manifold gasket all gone, required a head doctor.
Will look at that spot in a few.
Thanks heaps mate.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2850883
yeah if your running a ceramic honey comb filter
but if you have a descent stainless steel after market cat with a stainless steel filter you shouldnt have this problem.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2851018
A picture speaks a thousand words...
SO
here be a picture of the apexi solenoid.
These aren't around the wrong way are they?
here's the other angle
Now the other (original?) solenoid that has the blocked off pipe, wtf? the other one goes to this other pipe which i suppose is internally venting something somewhere.
Finally an overhead shot hopefully showing everything.
I'll take my camera to work, so if you need any more pictures let me know.
Thanks once again guys, and remember if we can't fix it via a forum, i'll put a carton of your choice in your pocket if i can come around and have someone show me whats wrong.
Cheers,
Edited by nsanity
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2851933
So on the way to work this morning, i went via the monaro. Some REALLY wierd shit is happening now. I have a distinct suspicion the AVCR has forgotten its settings.
Sitting in 4th at 100km/h off boost, plant your foot it rockets to 7k rpm, then falters back to 5.5k rpm and goes forward as you'd expect it to.
Its almost as if the clutch was held in (maybe i need a new clutch, but that would be a coincidence as well.)
Boost still wouldn't budge above 0.65.
Any chance it could be this stupid hot weather we've been having? not to mention its a nice chilly temp this morning?
Edited by nsanity
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2851960
That old solenoid and tubing could all be binned [i think] its not doing anything. Just block off/seal the holes in the pipes.
I'm not sure about the apexi solenoid and the hose positions, you need the instruction manual to see if they are hooked up right way round [i've got a Hks unit and its different obviously].
Otherwise all you hoses ect look right to me.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2852004
Unfortunatly i know little about EBC's but my Manual bleed valve is setup as such
Inlet pipe hose into bleed valve then it comes out the other end and goes straight into actuator which is what it looks like yours does. The only other thing i noticed is your lines are not really that direct i was always told with boost stuff to make them as short and straight as possible.
As tridentt also said you dont need the stock two stage boost controller any more just make sure any possible leak is blocked off but if it wasent you would probably hear a hissing sound/ idle problems.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2852005
Ckeck if your actuator arm to the wastegate is OK and not loose.
Try cleaning your AFM, don't touch it, just use brake cleaner or carb cleaner and squirt it heaps. I wouldn't have the afm plug sitting up like that, rotate it so that the plug is level or facing down a bit it stops moisture etc sitting there and getting into the afm box.
Otherwise my remote help abilities are all worn out.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2852012
hhaha, dead clutch.
its in at the shop again :)
thanks for the offer widebody
Saw your car in the shop today. I went in to see Marc about a wheel alignment for my Chaser, also to look at his wreck. nasty stuff that is.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2854796
Problems all solved yesterday, thanks to the guys at Autotech.
Would have gone to ESP on Jayce's recommendations, but he didn't give me the number! :woot:
Its all better though - i missed her.
I did too get the number to you...only two days late,LOL!!
Car sorted?
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2892684
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
