Hi Guys
I am looking at getting the LED's for my R34, does anyone have anypics of these lights on their cars?
Also, does anyone know of any traders on SAU that sell these for the R34?
I know Just Jap do but they're pretty expensive.
Thanks guys.
https://www.sau.com.au/forums/topic/153158-rear-led-lights-for-r34-gt-t/
Hi Guys
Thanks guys.
Where did you get them from? How pricy?
Hi Guys
Thanks guys.
Ever looked at the price of genuine Nismo LED rail lights?
no i have no clue about prices for genuine nismo lights.
the only lights i have seen are the Just Jap ones, but I get the feeling they are no where as nice as LOULOU's lights.
these are quite nice too
its the clear Altezza or whatever they are called that are filthy... in fact they produce gay pink light!!!
Im pretty sure LouLou's are the same as those from Just Jap
That's a "nice" car !! Love your choice of wheels too. :P
can you see the wheels??
LouLou mind telling us where you got yours? those LEDS are not in nengun or greenline...cheers
you should really remove your plates when you post pics..cheers
Hey guys,
I purchased the tail lights from Slidewize imports, Zac's a great guy helped me purchase them with ease.
As for my wheels i dont know what they are called but they are RAY'S as they have the badge on them but they came with my car when i bought it.
The clear LED's that you get from Just Jap are way different to mine even when they light up and they do look ricey.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
