Hi Guys
I am looking at getting the LED's for my R34, does anyone have anypics of these lights on their cars?
Also, does anyone know of any traders on SAU that sell these for the R34?
I know Just Jap do but they're pretty expensive.
Thanks guys.
https://www.sau.com.au/forums/topic/153158-rear-led-lights-for-r34-gt-t/
Hi Guys
Thanks guys.
Where did you get them from? How pricy?
Hi Guys
Thanks guys.
Ever looked at the price of genuine Nismo LED rail lights?
no i have no clue about prices for genuine nismo lights.
the only lights i have seen are the Just Jap ones, but I get the feeling they are no where as nice as LOULOU's lights.
these are quite nice too
its the clear Altezza or whatever they are called that are filthy... in fact they produce gay pink light!!!
Im pretty sure LouLou's are the same as those from Just Jap
That's a "nice" car !! Love your choice of wheels too. :P
can you see the wheels??
LouLou mind telling us where you got yours? those LEDS are not in nengun or greenline...cheers
you should really remove your plates when you post pics..cheers
Hey guys,
I purchased the tail lights from Slidewize imports, Zac's a great guy helped me purchase them with ease.
As for my wheels i dont know what they are called but they are RAY'S as they have the badge on them but they came with my car when i bought it.
The clear LED's that you get from Just Jap are way different to mine even when they light up and they do look ricey.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
