I have had an intercooler fitted and if im on the moterway and drop down to third at 80-100kmh and floor it, when i get to 5000rpm my moter cuts out for 1 sec and then kicks back in. When i turn my boost down it will not cut out but i have no power. Do u think my tap is faulty??? And I have no power FC. Please help
https://www.sau.com.au/forums/topic/153180-do-i-have-a-boost-fault/
I have limited knowledge about this sort of problem, but it could be your spark plug gap is too far. The new amount of airflow from your intercooler / increased boost might be effecting it.
Search for that, there has been a number of posts on it.
Cheers,
Dave
check all your hoseclamps to make sure they're tight, i had a similar problem and that was the cause
what boost are you running (on high boost)? Is your car stock? Does it seem like its hitting a limiter? Btw this is more a forced induction section issue.
Edited by 33NIZ
Sorry but hoseclamps to what? the tap?
everywhere but in my case it was the cooler piping itself, right before the throttle body :laugh: it was tight enogh to not blow the hose off completely but loose enough so that once it made above say 5psi it would spring a leak, all boost would go out and the motor would cut out for a sec
You are hitting boost cut...
Either get an aftermarket ecu or an safc or similar piggyback ecu...
The car is basiclly cutting out due to an overboost error, the ecu is trying to save the engine...
So when you turn the boost down it does not cut out, and you have no power because you turned the boost down.... :(
Also search topics "Boost cut defender, fuel cut & boost cut"
There are many ways to combat it with out spending allot of money, but if you have a stock ecu id spend the money personally and buy a PFC straight away. Its not safe to run 12psi on a stock ecu with standard fuel maps...
i had this when i got my FMIC installed, but it was because of a hose that goes from the boost sensor to the BOV had melted shut(caused boost spiking so engine was retarding itself). replaced hose and problem is fixed.
it was also recommended that i check my plugs,coils, get a ecu or piggy back AFC and get a tune.
also if u got a K&N filter they can get oil on ur AFM which can cause issues so u may want to look up the tutorial on cleaning your AFM :(
Col has hit it on the head, this is why I asked what boost you were running and whether it feels like your cars hitting a limiter. I probably wouldn't be running in excess of 12psi all day anyway, especially not in this hot weather. Your car may be spiking as well, causing the ecu to boost cut but then when your boost falls back it allows it to go. Regardless, the only way to fix your problem is to do one of the things mentioned above, saving you money later will be to buy a pfc or safc at least.
Good Luck, Matt
Edited by 33NIZ
So when you turn the boost down it does not cut out, and you have no power because you turned the boost down.... :yes:
you beat me to it col, sure sounds like a boost cut.
has someone mentioned fuel cut?
the ecu senses too much of fuel or air (boost) and cuts it. most likely when u just get it to full boost as it will spike.
PFC will fix.
i hit fuel cut on a CA18DET at 22psi.. well it was 22 as the guage went to 20psi :)
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
