Hey guys,
Have had trouble starting my car only sometimes lately. Today it took me about 10 turns of the switch to get the starter motor to turn over the engne.
I get in the car, put the key in, turn it past accessories to the 'ON' position I guess, let the fuel pump go for about 5 seconds before turning the key to 'START' and nothing.... just cuts out the radio. Tried it about 7 times, then took the key out, turned it around, did the same thing, did the same thing first attempt, and then on 2nd attempt fired straight away.
Has this happened to anyone else? And what could be the causes?
Worn out ingition barrel not contacting anymore (I have no idea how it works inside the barrel)?
Starter motor contacts bad??
It used to only do it maybe once or twice at most, and only usually every 5 or so times of starting the car (it would usually strart straight away), but yesterday afternoon and today afternoon I had trouble.
Any other ideas?
Thanks,
Fixxxer
https://www.sau.com.au/forums/topic/153238-starting-problems/
If the key goes in and turns to start normally the first time before flipping it then its got nothing to do with the key or barrel. However commodores use an anti theft device in the key head that flipping the key sometimes helps, but thank god you dont have a commonwhore!
Most likely a starter problem. To be safe you should get a multi meter and load test the battery. First unplug the ignitor so the car wont start. Attached the two terminals of the multimeter to the battery terminals then get someone to try cranking the engine and while its winding over watch the reading on the multimeter. If it drops below 10 volts then your battery is dieing. If not and it stays around 11-12 volts the battery should be fine and you can be more sure its the starter/solinoid causing the fault.
Battery should be fine, its a good battery, I replaced it only about 3 months ago....
It's not like the starter is struggling to start the car, it's like the power is not getting to the starter, and then suddenly i turn the key the right way or something and it fires instantly.
Fixxxer
OK then we can rule out the battery, good. Next look at the starter & solinoid (which are combined) and earthing of the circuit. If there isnt a good earth (strap) you may aswell be not supplying enough power as its the same end result.
Deren
I had the very same problem on my car some time ago!
It ended up beeing the front + and -poles on the left side of the engine bay.
The thing was that the prior owner had connected front-lights to the +pole and that created a gap big enough for dirt getting in and ruin the connection.
Apperently the connection was good enough for panellights and such, but not good enough for the starter.
If i recall correctly i think the windows wouldnt move either...
Hope that helps!
As the brushes wear in a starter you will get an inconsistent starting patterns. But I have also seen a brand new battery off the shelf that I have had to fit to a customers car and it has had a brake in between the cells.
Do what Deren said by checking battery voltage, whilst cranking - this will give you the best indication, also check you main battery lead going to the starter - if these look ok - its time to pull the starter out, and give it to some mug they call an auto electrician :P.
Cheers
Sumo
Ok I will look around the starter motor and see if there is anything wrong with connections.
Next I'll check the battery and connections to the battery, but like I said this doesn't seem to be a problem as there is plenty of kick to start the car when the starter works, and this has been a problem ever since I got the car a year and a half ago (with a different battery).
Fixxxer
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
