"so you can get a tuner to tune 100%" Its still going to cost you money regardless whether you tune from a bas map or not most likely the same amount of money, esp when everyones car is different, and even if you got one close to your specs, doesnt mean the car is in tune, as every tune is different, best time and money is spent on getting it done in full when thats what they usually do and go from there, less stuffing around then, as they usually wipe the map which is currently on there anyway and start from fresh.
But hey good luck if you can get it
Cheers A
https://www.sau.com.au/forums/topic/153246-e-manage/#findComment-2850909
    • Goddam! Thats the dream, neo heads seem hard to come by these days though, best I've seen is $2-3k or there's a full motor for $7k atm
    • Cheers for the input, 450kw on poncams is impressive! I assumed you'd need 264 or 272 for that power level, good to know you don't need to rev that high to hit it, just don't want to buy the cams etc then find out the hydraulic lifters suck haha The box will be getting reconditioned too, possibly an aftermarket gearset if it turns out they're toast, cheers I'll keep that in mind
    • I think definitely get a manual oil pressure gauge on it then. Double check if it's really dropping pressure that low.
    • yes sorry i should of spoke better, all sensors are grounded into their specific homes in the ecu, the ecu is then grounded to the chassis itself along with the EFI relay.
    • I'll check the wiring plan tomorrow. Now when you say ALL the earth's are to the chassis, is that including the sensor ground from the ECU? Certain items should not be grounded to the car/body/chassis, they should ground back to specific ground pins on the ECU.
