Hi!
Sorry if my english is a bit bad.
Im thinking about putting a mitsubishi td04-19t och my RB25det.
would like to have some feedback about it.
How is the 19t compared to the original?
(I know the turbo is'nt a direct fit)
Cheers Christian
Edited by no_brakes
https://www.sau.com.au/forums/topic/153247-mitsu-19t/
I think you'd be going a step back with the TD04.
Look here for a heap of info on Mitsu Turbo's - http://www.zerotohundred.com/newforums/sho...ead.php?t=26477
I'd be looking at atleast a TD06-20G or a later series Evo TD05 for response if you want to use a Mitsu turbo
https://www.sau.com.au/forums/topic/153247-mitsu-19t/#findComment-2851346
Ok..
ive been told that this TD04-19t "with #7 exhaust housing" is capable of atleast 340hp. and it would give a great spoolup to.
How much can original make?
Im not aiming for much over 300-320hp at the moment and would like a turbo that gives full pressure quite quick.
(The thing is that my standart turbo hasent much more to give, and sweden (where i live) is'nt the greatest place to look for used skyline parts.. or skyline parts at all :thumbsup: )
Edited by no_brakes
https://www.sau.com.au/forums/topic/153247-mitsu-19t/#findComment-2851564
Standard turbo would flow 270 rwhp with all the support mods. What mods have you done sofar?
Fast spool and 220-240rwkw (~300hp) would be the TD05-16G. You can get them of Mitsubishi Evo's.
So far its just blitz nur catback, decat pipe, pod, and a hks evc. 3" downpipe will come with the new turbo installation.
does the TD05 16G fit the t3 flange on the exhaust manifold? (cause the td0419t fits direct on with only a small "flange" "gasket" between standard t3 "gasket" and the turbo flange)
but it dosent have to be a mitsu turbo, its just that i can get one for decent money, and its pretty easy to fit.
Edited by no_brakes
https://www.sau.com.au/forums/topic/153247-mitsu-19t/#findComment-2851832
TDO4 and early(vr4 and evo1-3) have the same flange pattern, but nowhere near the same as a skyline, late tdo5'5 (evo4+)are a nightmare, steer clear, they spin the other way, and have a funny shape splitpulse exhaust housing.
this is the turbo, the exhaust entery has the exact same pattern but you need the flange seen in pic between the turbo and the manifold.
I think if i rememer right this type of turbo comes from a Volvo v70R
And will manage to flow atleast 340hp
Edited by no_brakes
https://www.sau.com.au/forums/topic/153247-mitsu-19t/#findComment-2854214
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
