Vehicle: 1989 Skyline GTR
Problem:
- Engine wont rev past 4500rpm - 5000rpm starts holding back and missing real bad (its worse when its hot starts doing it at about 3500rpm)
- it revs upto the redline when in neutral, and idles fine, the revs drop (slightly) when you first touch your foot on the accelerator.
Done:
Checked and cleaned AFM's
Cleaned and checked plugs (NGK Irridiums)
Pulled out coilpacks and sealed them with high temprature silicone.
checked all plugs and wiring
Been at this for 3days trying to work things out... im out of ideas, it seems as tho its a coil-pack break down but who knows.
ANY help appreciated (A.S.A.P)
UPDATE:
pulled off the CAS and found the shaft was broken....so i replaced it with a new part...and it still wont fire...checked injector pulse again and it still has nothing.
checked for ECU error codes and it flashes up *55* - which means everything is all good.
im now lost as to what the problem is... what pin on the ecu controls the injector pulse? and is there a relay to check or a fuse, or antoher earth wire?
Edited by -GODZLA-
https://www.sau.com.au/forums/topic/153258-engine-troubles/
Ok,
Car died on me yesterday, and will now not start, spark and plugs seem fine too me (did as mentioned in first post.) also pulled a coil pack out and turned the engine over and it sparked.
fuel pump seems to be fine, (havent got anything to check the pressure but it pumps out flatstick)
also the pump keeps running and dosn't switch off (shouldn't it turn off once pressure builds up in the fuel rail?). - also pump is a little noisy.
i also thought it could be the little fuel regulator at the end of the fuel rail, i thought it may be stuck open and just feeding back to the tank.
- so i took the return pipe off to see if it keeps pumping out... but it doesn't pump out when fuel pump is on...it only does it when i try to start the engine.
also could it be somthing that controlls the injectors?
hope that makes sence to someone?
cheers for any help.
Edited by -GODZLA-
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2858473
yep this is once it stoped (checked it aobut 20 mins ago)
cheers
if you want to check that it is not low on fuel pressure, try clamping the return line and see if it will start, i assume the spark plugs are not drowned in fuel? if they are then it wont fire
if the spark is good and fuel supply is good it may be worth while checking timing marks, perhaps the belt has jumped a tooth?
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2858542
if its not your fuel pump id be looking into your actual coil packs. clean them out lightly with a dremil drill or some steel wool.
ok iv tried a new fuel pump, and it doesn't help.... but just realized i can hear a relay clicking off after 5 sec and it turns the pump off ... the relay doesn't give the pump time to get fuel to the engine...so what controls
this relay is my new question?
cheers to everyone's help so far
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2858621
some pumps do that, some pumps dont, the clicking would be the fuel pump relay, if you had a problem with that you would have no power at the pump
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2858647
disregard the fact that the pump might not be running when the ignition is switched on and check to see if you have actual pressure in the lines when the engine is cranking over. if you do, this will effectivly rule out the pump.
Get an LED test light and test the injectors to see if they are pulsing while cranking.. which will also rule these out. Tehn thats just about the fuel side of things.
One thing to check that no one has mentioned is the Crank Angle sensor.. if this is failing it will cause the crazy missfires at revs... and if it has failed it wont start at all...
other things to check would be AFM's, Timing belt and timing in general, may have jumped, Ignitor for coilpacks, power to coils, and packs acctually firing,
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2858694
ok, i just hard wired the fuel pump to the battery and and it now pumps fuel to the rail...but the fuel is constantly running back to the tank... so its got plenty of pressure in the rail...so i pulled a spark plug out and it was damp with fuel. so i think the regualtor is fine...so im confused as to why it wont start...spark is there and so is fuel..........................................................................
EDIT: It has a new timing belt on it as the engine is fairly new
also how will i know if the Crank Angle sensor is buggerd or is it out of place maybe?
cheers
Edited by -GODZLA-
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2858753
if the crank angle sensor is buggered you wouldnt have any fuel or spark UNLESS:
the crank angle sensor has broken its shaft and spinning intermittantly and firing etc but at the wrong time, i had this problem with my car (front cover removed but crank sensor bolted up) snapped the shaft,
also check the keyway at the end of the crank angle sensor spline isnt broken
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2859162
I don't think its the CAS tho, cause as i stated in post one before the car stopped it was missing under load at 4500rpm and when it got hotter, unless they do the same thing when they are on the way out? i had it of earlier and it seemed ok
so in guessing for now injectors (somehow) or ignition module
Edited by -GODZLA-
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2859263
ok, i assusmed the injectors were working as the plugs were a little damp, but i checkd for injector pulse and there is none at all.
so would this be cause of a ground connection or loose wire or somthing (it wouldn't be a fuse as i said its somthing that was breaking down slowly) and now has shit itself.
cheers for any help
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2860450
ok,
i pulled off the CAS and found the shaft was broken....so i replaced it with a new part...and it still wont fire...checked injector pulse again and it still has nothing.
cheers
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2862132
The injectors and Ignition have seperate fuses in the harness.have to check each one im unsure which is which
make sure the timing is not over advanced or retarded.Skylines dont run at certain points.Did you install the timing belt correctly
is it series 1 or 2
They have a earth at the rear of the coil pack on no 6
make sure this is put back on.
have you tried jump starting the car
have you got comp in the engine
Edited by MR331307
https://www.sau.com.au/forums/topic/153258-engine-troubles/#findComment-2862459
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
