The injectors and Ignition have seperate fuses in the harness.have to check each one im unsure which is which
make sure the timing is not over advanced or retarded.Skylines dont run at certain points.Did you install the timing belt correctly
is it series 1 or 2
They have a earth at the rear of the coil pack on no 6
make sure this is put back on.
have you tried jump starting the car
have you got comp in the engine
Plugs are dry as a bone. spark is fine, im checking injector pulse with a light... it has constant (+) current on one side but no
(-)current on the other side
Edited by -GODZLA-
Hi,
I had the same problem it sounds like when i rebuilt my engine, (400rwkw RB26) My mate did not tighten a hose correctly and it would rev freely to redline, and idel ok, but when driving, as I started to make boost it felt sulgish and would only go to 5000,5500 rpm and start to back fire and not rev any further.... I found that the plugs fowed, and it was not starting correctly, try to check your hoses for a spilt/loose clamp. You can connect a compressor to the inlet while you block off the extra hose and flow air through, try to keep it under 15 psi.
See how you go!
i assume u mean a test light?
ive never hooked up a test light to an injector to know what it would show
if u wanna check pulse you need a noid test light, it will actually show you the pulses
- yes it was with a test light and a logic probe...
- the plugs are sparking also
Edited by -GODZLA-
sorry man what is a logic probe?
logically speaking, you found the problem was the broken CAS shaft, that is a obvious reason why it shouldnt go..
so logically the problem is there, possibly a faulty part? or possibly but i doubt it damage to the cam gear where it meets up with the CAS
yeah i was sure it was gonna go once i put the NEW cas back on... :D
Maybe i should pull the new CAS off to see if it has snapped again.
the logic probe is a LED light thing...im not real sure how it works but oh well... a test light wuold be more than enough to check injectors.
**The HICAS (rear steering) is really noisy now to and the light keeps flashing on the dash...damn it..(is this normal?)
Edited by -GODZLA-
yeah i was sure it was gonna go once i put the NEW cas back on... :action-smiley-069:
Ok, the car started this morning and the died after 5mins of idleing...So i pulled off the CAS and its snapped the brandnew CAS shaft... how can i mae sure everything is aligned properly? or is there other reasons it snaps?.....very costly part..i cant go breaking anymore of them
Edited by -GODZLA-
ive heard of this before.. and tis got to do with the cam shaft being out of alignment with the CAS shaft... take your exhaust cam cover off and suss out to see if all the cam bearing caps are tight and seated properly.. turn the motor over by hand to make sure the cam spins true and straight.
ok, CAR IS GOING AGAIN -----so far so good
Turns out i pulled the cas bracket off that is behind the cam cover..and found that it was missing one of its two alighnment dowls...which as a result was putting the cas shaft out of wack...and breaking the shafts.
- also car is still missfiring under load..so im trying a stock ecu and a coil ignighter module 2moro.
cheers for everyone's help its been great... still not 100% but progress has been made.
cheers to all
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
