I have a S2 R33 GTST.
and i'm jsut wondering if it has a petrol light that comes on when the tank is low.
so far. my cars on empty. with 525km's on the trip meter. so i'm guessing it would be almost completley empty. and i havn't seen any light come on the dash.
i was just wondering if they have one?
thanks.
https://www.sau.com.au/forums/topic/153279-noobest-question-ever/
Someone with an S2 confirm that the fuel light comes on like all the other lights (ABS, Airbag, HICAS etc etc) when the accesories are switched on?
I'm pretty sure the fuel light is the one on the far left...and mine never comes on
Be careful incase the globe has gone like it has in my Evo. Might replace that tomorrow actually. Got a bit too close on the DECA trip in November as a result! :woot:
my globe works, and unfortunately shows up quite often. i had a lot of consumption issues, so i got into the habbit of seeing almost exactly how many kms i was getting to each tank.
pushed my luck one arvo, light was on, then realised i had about 30kms to the next petrol station, made it fine! (although there was barely enough fuel to power the light, let alone the engine)
lesson learned!
does everyone else's gauge drop in large increments? mine does basically 100kms, then drops exactly a quarter in one hit. doesn't make much different i guess.
end ramble... :thumbsup:
525kms? thats heaps.. i do about 350 and im on empty.. and that just driving around normaly.. but then again you tank is prob bigger...
i think my tank is 65 litres, but i drive like a granny, so i don't attract police attention, as my car isn't complied or registered yet. i'm just a p-plater driving on a trade plate atm.
i havn't every seen my light come on. and when i put the ignition on. i don't see it come on either.
:s.
i'll check the globe when i receive my white faced dials from group buy and have to pull apart my dash.
my GTR will hit 500 mixed. not DORIYA STYLE..
but havent gone below 1/4 only been on less on quarter when i picked up from the yard.
:) t'was a day to remember :)
R32 GTR have fuel lights too.
careful not to run ur tank out too much u cna clog injectors and or run lean blah blah blah BANG
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
