I often Kramer it, and In my series 1 when the fuel is low the light comes on and it tries to stall around left hand corners! the most fuel it has ever taken is 63l allowing for a comfortable 2l. Best k's ever was about 580, average is about 300.
My car seems to like V power racing, finally no pinging!
:P I do that in my Van, because I hate filling it up during the day. I got like 560 out of it once, but like you said, it started cutting out
Can someone confirm if the fuel light turns on when in ingnition for a R32?
Mine doesn't light up and wondering if this was a feature added into r33+ :(
I have a 93 R32 GTS-T and the fuel light does not light up when turning on the ignition.
And incase you are wondering, the fuel light in my car does work because it came on today when i parked at work, i parked on the side of the road and the road dips a lot into the ditch so the car was on an angle and the light was on. When i pulled away after work the light wasnt on and the fuel gauge rose a bit again, but regardless it had done 500km so i knew it was time to fill up, but it took 51.5lts, so it wasnt terribly low!
Edited by r32line
holy shit. 525km on the trip meter, im lucky if i get 300km. i usually get around 280km. i cant believe it sorry mate it just amazed me to see someones skyline doin that. i got mates that get around 450 max, i got a bloody dud skyline i tell ya. it does like a bat out of hell but standard injectors and computer. dont know whats going on
bet your 02 seonsor is fooked
That's pretty bad fuel consumption, something definately not right there!! I always get 10 - 11/lts per 100km and a lot of that is in busy traffic and when im not in traffic im often stretching its legs. Overall i dont drive it that hard but i certainly dont putter around! Has your consumption been like this since you got the car? Might be worth putting it on a dyno and checking the a/f ratio's etc...
It changes from orange to red >_<
I don't understand? are you saying it comes on orange when you are low, and if it gets lower then it goes red? i've only ever seen mine as an orange light.... But i have never let my fuel tank get really really low.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
