I often Kramer it, and In my series 1 when the fuel is low the light comes on and it tries to stall around left hand corners! the most fuel it has ever taken is 63l allowing for a comfortable 2l. Best k's ever was about 580, average is about 300.
My car seems to like V power racing, finally no pinging!
:P I do that in my Van, because I hate filling it up during the day. I got like 560 out of it once, but like you said, it started cutting out
Can someone confirm if the fuel light turns on when in ingnition for a R32?
Mine doesn't light up and wondering if this was a feature added into r33+ :(
I have a 93 R32 GTS-T and the fuel light does not light up when turning on the ignition.
And incase you are wondering, the fuel light in my car does work because it came on today when i parked at work, i parked on the side of the road and the road dips a lot into the ditch so the car was on an angle and the light was on. When i pulled away after work the light wasnt on and the fuel gauge rose a bit again, but regardless it had done 500km so i knew it was time to fill up, but it took 51.5lts, so it wasnt terribly low!
Edited by r32line
holy shit. 525km on the trip meter, im lucky if i get 300km. i usually get around 280km. i cant believe it sorry mate it just amazed me to see someones skyline doin that. i got mates that get around 450 max, i got a bloody dud skyline i tell ya. it does like a bat out of hell but standard injectors and computer. dont know whats going on
bet your 02 seonsor is fooked
That's pretty bad fuel consumption, something definately not right there!! I always get 10 - 11/lts per 100km and a lot of that is in busy traffic and when im not in traffic im often stretching its legs. Overall i dont drive it that hard but i certainly dont putter around! Has your consumption been like this since you got the car? Might be worth putting it on a dyno and checking the a/f ratio's etc...
It changes from orange to red >_<
I don't understand? are you saying it comes on orange when you are low, and if it gets lower then it goes red? i've only ever seen mine as an orange light.... But i have never let my fuel tank get really really low.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
