Hello,
I currently own a 180sx (sr20det) with around 200rwkw. I'm planing on selling this soon and buy a late model R33, My opinion is that i reckon Skylines are a stronger built car in and out and my power goal will be no more then 250-270rwkw with nice deep dish wheels, a nice clean streetbale kit with a good suspsension setup, clean interior with the ocasional track day.
I've come to this site not as a noob but with massive knowledge of tuning and modyfying silvias and will help out all i can to fellow menbers.
ps; i've come from Ns.com and have been a member there since 02
Cheers!
Edited by GZillar
https://www.sau.com.au/forums/topic/153330-hi-im-new-to-this-site/
Welcome to the crew. RB power FTW =D
(if only Skylines weren't so heavy!)
*puts flame suit on..*
Invest in carbon doors, boot, bonnet, fenders and get a custome made aluminium roof! :)
you've said the all the right things.....you may pass
Oh thank you :P
gee i dunno guys been on ns for that long might have affected him somehow
welcome btw
Huh? :huh:
awesome first post. i'm putting u on my list!
Just like leaving an apple on the teachers desk :(
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
