attempted the white dial mod to dash cluster last nite
took 2 smokes straight and i had it done with all the green caps removed and reinstalled (did it in carpark whilst eating hj's as i always carry 3 toolboxes with me full of tools (just incase!))
only problem... they were a yellow tinge... so today took cluster out again and installed phillips ultravission hyperwhite/blue globes...
the cluster is now super bright - i love it... however it now has a green tinge due to the factory dials green coating... so im wondering how to fix this? it has been mentioned to use thinners on the dials to remove the green?
any recommendations?
look closer at the pic i supplied up top there is no green on the cluster... he has removed the factory green on the dials... will thinners work and not f**k shit up? what to use?
  • Replies 73
In the same boat, the cluster looked orange, so I used three T-10 Narva Arctic Blue bulbs and the green coating is now visible. I couldn't find anything T-5 sized though, except for these Monza LED bulbs, but I chose blue and it actually coloured that part of the dash blue. :)
I'm hoping this green coating comes off with a wipe of thinners :(
i hope so too as im super keen to get uber white
also noticed that 1 of the smaller bulbs (not parker size) lights up the speedo from 120-180... so everything on my dash is bright and tinged green apart from that part which is duller and yellow
This is the T-5 bulb that I was talking about, I'm gonna go looking in other auto shops today for something suitable.
led bulbs look shit... just want normal white
went to autobarn - narva do have t5 sized wedge bulbs... i picked one up $2 each... its just normal white not arctic however they said they do do a super white led t5 size - which i will try after i try this normal narva t5 bulb... i really dont wanna use led's as it will mean having to replace all the phillips ultravision ones i just bought and wont be as bright...
just need this green coating gone - whats the go???????
tried to remove the t5 bulb from its holder... it wont come out! not without breaking it... and had a better luke at the new t5 bulb i got which is just basically a new factory normal one so i dont think itll do much
sent the mrs off on a mission tomorrow to find an ultrawhite t5 to match the t10 phillips ones ive put in
she also came up with the idea of tinting the clear plastic cluster cover in 20% tint... so shes doing that tomorrow (hope it doesnt turn out shit!)
ok i finally got home from working on my car, i tried the thinner thing and it works.... but i wouldnt suggest it because it works on the plastic too lol, if your very careful it will look good , i didnt have another part to the cluster to try prepwash on but i think that will do the job perfect. pics in the morning... its sleep time now :D
when f**king around withe my cluster again last nite
i noticed on the back of each dial up to about 80 it is green... then 90 to about 130 or something the lines are white on the back... then green again to 180... wtf?
take pics of the back of the actual dials removed from the cluster? how did it go getting the white and green off? also that shit doesnt feel like it would come off... it sounds like a zipper when you run your fingernail over it
SCORE!
gf did browsing on the auctions this morning. 90-91 cefs had completely different clusters with factory white... i just purchased one now which will be here in 2 weeks... tacho goes up to 9k instead of 8k aswell
no more dicking around with factory cluster
now we wait... if anyonelse wants a late model cluster i can get several more... pm me :action-smiley-069:
ill put pics up tonite of one
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
