  • Replies 73
  • 4 weeks later...
updated cluster arrived
with the newer model cluster - caps arent in the cluster... theyre condoms over the globes... so peeled them off... then decided to put my phillips ultravision artic globes in
turned it on
ba bow... bright fkn green
its the green on the dials... the mrs is doing OT at work today so shes trying the turps thing... i cant see how it will work as there doesnt seem to be a non green layer on the dials...
so now were all back to the same dilema - how to get the white!
the g/f here :(
got half of it done today whilst at work with a razor and turps :happy:
just an idea .. it's never going to come out 100% white as the plastic backing has a slight green tinge ...
another option if your after something INTERESTING is by sticking some clear coloured contact to the back .. ie pink / blue / purple / bla bla bla !
also the orange needles can be made into clear by simply turpsing off the coat of white/orange !
found out from a mate there is a gauge place here in adelaide near my gfs... his mate had his gauges reprinted
so might see if they can reprint the front part of mine onto clear sheet... or white... i thought it would be harder but supposedly these guys can do it
also gonna change needles to red also!
doesnt the newer model cluster conflict with the speed sensor? i know it's got that cable driven thing in the back.
i was having trouble with my cluster. PFC wasnt reading speed, and got told to change to another one from the same model, i was also told that the later model ones dont work nor do the RB25DE clusters.
works fine
only thing not working in my new cluster is fuel gauge... either due to incompatability or just broken gauge from japan (prolly reason why the guy was selling it lol)
waiting on my callback about reprinting these dials... im thinking itll be 500+
Phwoar $500+? that's a bit of money just for some white illumination...
I was thinking more along the lines of scanning the cluster dials (with a decent scanner), slight modification of the image on the computer, then go down to a sticker shop and have it printed as a vinyl sticker. Put the sticker on a piece of white acrylic.
