SOLD
Dec 07" NSW rego
118xxx kms
HKS Turbo timer
Front Mount Intercooler
3 inch Exhaust
Immobiliser and Alarm
Kenwood Mp3/cd player and speakers
Vertex Bodykit
18" x 8.5/9.5 Deep Dish WEDS Vaspar Rims with New front 235/40/18, rears 235/40/18 about 70%
Tinted Windows
Freshly re-gassed air con.
pm me here, in Sydney.
Cheers Phill
Pic's:
Edited by phillb
https://www.sau.com.au/forums/topic/153370-sold/
hi
will u be intrested in clean swap wid honda civic VTI-R Coupe Black 11 month rego wid 109000 ks
cheers
ADI,
Thanks for your offer, but it's not really suited for the direction I would like to take, Good luck with the sale of the Civic anyway :iluvff:
Phillb
https://www.sau.com.au/forums/topic/153370-sold/#findComment-2905127
how hard is it to do a manuel conversion on these?? i no only the twin turbos came out in manual standard but thwey are pretty rare
It's not too hard as long as you have all the right parts, such as JZA70/80 gearbox/clutch, Tailshaft, pedal box to suit? Manuals are quite rare apparently there were only something like 10% made in total production.
I had considered it for about a second, but it's such a good cruiser in auto :)! I am just looking for a change in the form of a manual rwd preferably Nissan.
https://www.sau.com.au/forums/topic/153370-sold/#findComment-2909181
  • 3 weeks later...
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
    • Interesting. I've not dived into the cleanliness of the factory CAS. I'm curious if the variations are less of an issue if the OEM sensor were brand new. Optical sensors if they're starting to get dirt and crap into them as they're getting older would definitely cause issues as they age.   It's an interesting point to keep in the back of mind for me though
    • Hmm. Tough one. Without knowing where the conductivity value is supposed to sit, it's hard to know whether a standard DMM set to an available ohms setting would be able to measure anything. Ohms being the inverse of what we're talkng about and probably good enough for the girls I go out with. But if you want to go all hoity toity with a 4 wire rig - go ahead. It can only be more accurate - just in case more accuracy or repeatability turns out to be required. If you're going to the effort, just go chuck the ohm-mage probes into the car's reservoir and see if you can measure anything at all?
