The information I have found on this sensor is pretty in-conclusive. Could someone set me straight on this ?
IS this a exhuast temperature sensor ?
What is its purpose in the miriad of processes involved in running the beasty 2.5lt donk ?
This question may be redundant but would it matter if I was to simply leave this sensor out ? I assume not perceptibly since i found A pair of posts stateing that they hadnt nticed anything but this isnt quite the fact i was looking for. maybe over time something could go bang so I ask.
This is currently a problem for me as I have recently aquired a wide body catco 3" cat to match my 3" cat back system and only need a front+dump aka batmbl revised version. ^^
the catco cat has no port for this sensor so I need to know if thats a problem, I also need to know where would be an equally good place to install the sensor should it be a requirement that is not in the cat, I dont want to hinder flow and havent seen the sensor itself out of the cat so i dont know if its going to cause a choke point... possibly why its in the cat to begin with ?
if the cat is the best for this reason, can i just drill a hole an tap a thread in or is there some part of hte cat process I could damage doing this, assuming there is a chemical reaction going on in the cat to change gasses and prevent the toxicity shite aka the point of having a cat in the first place.
new cat... what to do ?
so pro's / con's of removing would be something helpful.
also in hte future a second hand pfc or equiv management system will eventually go in, will this sensor be of use to the tunning process or the day to day running on a non factory ecu? will they make use of it ?
links in various directions could help me...
cheers
Thanks guys.
Am I likely to get to a range of heat. in my exhuast that could cuase a problem ? Im assuming this is some sort of indicator of how hot the engine is running / burning ? oil temps probably being a lot more relevant, but what would this be providing a warning for ? if the exhuast is hot i doubt it will likely get to a point where this would cuase some issues. I dont know enough about it to judge that this is a safe risk to run unprotected, I dont believe it to be likely but what risks are involved... i might be a wet blanket but i wana be sure im taking an acceptable risk something isnt going to pop due to me removing something.
I've run all my cars (4 years) without the sensor.
When i say nothing will be affected, i mean it :sick:
The sensor is only there, if i recall correctly, to tell you if the cat is overheating due to mixtures not being right in the factory setup.
You are no longer running a factory setup, so it does not matter.
Thanks guys.
The temp warning is for the cat - the idea being, if the cat gets blocked by one means or another the temperature
on the upstream side will go way up. View it as a health-of-cat sensor. Exhaust shops use this as a means of
gauging just how blocked your cat is :)
If you delete it you won't do any harm as long as you're cat's not blocked.
Regards,
Saliya
When i say nothing will be affected, i mean it :laugh:
Same here for me, 3 different cars and never had a problem not running it.
I had it in my old track car and the only time i used to see the light was when the car was warming up on idle on the dummy grid.
Yank the sucker out, put in your new unrestricting cat and enjoy :miner:
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 😄
    • They sure do, great for when you need to chuck a sickie 😅   You should definitely give the beast a squirt on the track, great to enjoy the car
