are you guys sure the r33 thermo fan doesnt switch on with aircon? i thought it did. not constantly, but as needed.
Yes you are right, even R32 but i think we'd like to have the fan turn on a bit earlier than what set (factory temp set at 94degree i believe) by Nissan just to be on the secure side.
  • 1 month later...
  • 4 weeks later...
Thanks for the how to Cubes, worked a trick. But I think its a little too late for my compressor, I think the summer period has over cooked it. Oh well I have a replacement one here.
What gas are you running? Our compressors are not designed to deal with the high pressures experienced with R134a gas.
Find an aircon specialist that is licensed to deal with R12a; a MUCH better option.
I've had both gases in mine and the R12a is much better. I can no longer hear the a/c compressor roar, I can no longer feel when it clicks in and out and the power it sucks out of the motor is hardly noticable UNLIKE R134a.
R12a is a more efficient and environ friendly aircon gas than R134a.
Don't confuse R12a with R12. They are two different gases.
yeh i converted it to R134a gas and ever since then have been having probs. 2 weeks after I had it done it built up too much pressure and stopped working. They had to release some gas and it worked again for a few months then the compressor went. I'll have to get the compressor replaced and then fill it with the r12a then.
haha ive converted mine to R134a.
The power drain is huge, wouldnt dare turn it on whilst idling at lights :whistling: When coming to a stop, i always put it into neutral and rev a bit so it doesnt stall it self :P
lol mine wasn't quite that bad but it made the car feel very very dull.
  • 7 months later...
i did this and it worked a treat,
also added another wire connecting it to the black side of the diode then ran the wire into my cabin with a switch that connects to ground, now i can turn it on via the switch or via the air con
Say ur radiator temp has rose a bit, just flip the switch and instantly the overheat fan will kick in and aid in cooling your radiator.
  • 3 weeks later...
has anyone tried this on an R33?
I'm about to replace my aircon fan, as mine is seized, and probably has been for some time. although the aircon is still quite good :blink:
now to work out how to get the fan out without removing the fmic :devil: . i tried, but it doesnt look possible, so i unplugged it for the time being.
Edited by Munkyb0y
  • 1 year later...
as hot weather has come around in victoria, this requires a bump up to the top :yes:
took my car to get an AC checkup and they told me to wire in the radiator fan startup.
One question, after turning off the AC is the rad fan still on? or does the wire+diode signal the rad fan to turn off?
  • 11 months later...
Yes, I would like to do this mod on my S2 R33 for this summer! Does anyone know if the fuse layout is the same as the R32's?
Also, does it actually make much difference to the air temps (inside the car) when you've just started the car and it's ultra hot outside, but you're sitting still? I'm finding that for the first few mins it never really cools down much inside if it's >35C outside and I'm not doing >40-50km/h. On the flip side, once I'm doing >40km/h would I really need this 2nd fan going whenever the A/C is on?
Oh, and what happens if the car reaches 91C but the A/C is off? Does the overheat fan stay off? Or, in other words, is the overheat fan now solely controlled by the A/C?
Edited by benro2
will be trying this mod its got 2 be 1 of the cheapest 1s out and it will give me a chance to check if my thermal fan works (i dont trust the 1 the panel beater fitted)
  • 4 weeks later...
likewise - when i had my regas done the mechanic also advised running the thermo fan would knock off approx 5degrees from my current internal vent temp which is @ 11degrees
this is a fantastic mod, i'll do this today :P
