just made this mod to my car & it has made a difference to the cooling of the a/c, i dont know how many degrees it has dropped BUT i can most certainly feel the drop in temp :P thanks cubes :D
  • 7 months later...
tried this mod and it works like a charm but i decided to change the pressure switch ($73 and plus gas$50) and make the fan auto. but anyhow thanks very much for sharing it with us and 10 out of 10 for instructions.
  • 4 weeks later...
took me a while, but I finally got around to it ;)
just to confirm for others. on R33 its the pin on the far left (driver's side) on both relays. Same as cube's original instructions for R32.
I found this pic on the internet.
It does look identical so I'd say yes.. Its the 1N4004
i havent put a diode in yet. the one above is rated at 400V 1A. Is 1A ok for this application?
Edited by Munkyb0y
  • 4 weeks later...
ok, i've noticed something strange. r33.
if i turn my ignition on, but dont start the motor, then turn ignition off, my ignition lights stay lit.
after some poking around, i discovered if i disconnect this mod, and replace the relays as per standard, the problem goes away.
anyone else have this?
  • 1 month later...
Did this Mod on my R33 yesterday but will see how it goes this week.
it looked a little bit harder than the R32 pictures but once you move washer bottle and undo the power cables (unplug battery in boot first) it help get under the relay.
I spliced into wire 2 on each relay (under the relay it will list what pin 2 is and then where that pin plugs into I spliced into that wire which was the left one for both)
  • 11 months later...
  • 1 year later...
I don't think this can be done on a R34. The 'blower' fuse is located inside the cabin. Can someone with a R34 comment on this?
I did it to my r34 gtt but I used the relay to kick in my electric rad fan relay ( aftermarket fan which ive done to many r32s aswell)
QUESTION: Will the fan get "burnt out" slowly wear out if the fans are turned on at speed ( 80-200kms) or would the wind speed going 200k on a "track" be nowhere close to the electric fan speed??? note extra fan is mount horribly through the rad core
cheers
  • 8 months later...
  • 10 months later...
Would also like to know if this works with R34 GTR, as my aircon is slowly begins to get warm when stopped at a set of lights on an extremely hot day, and cools down again when i'm driving, and my water temps seem to go up when i'm idling at lights but slowly comes down when i'm moving.
  • 2 years later...
I know this is a bit old but I have found out a much simpler way to have the Rad fan kick on then messing with the relay box and installing a diode.
very simple,
all you need to do is jump the over heat switch.
(This is a test jumper, I have an old temp switch I'll chop and solder as a jumper)
Fan will only kick on when you turn on the A/C.
this fan will only operate with the A/C system engaged.
With the A/C off it will not turn on if the engine runs hot, if it did the fan would always be on when the jumper is installed.
Best part is you can revert back within seconds
Edited by Nissan_Junky
  • Like 1
  • 2 months later...
Whats up guys. So I have been trying to figure some stuff out before I do this mod. I know this thread is very old but maybe the GTR gods can help me out. From my understanding the aux fan comes when temps go over 90c. Does the fan come on only when the aircon is on or does it come on any time the engine goes over 90c regardless. I ask because my fan comes on without a problem when the aircon is on and it goes over 90c but it does not come on with the aircon is off. The service manual under the coolant section says to jump the plug just like the user before me did but it only comes on instantly if the aircon is on.
I think I am having issue with the aux fan coming on independent from the aircon. I may be wrong so please correct me if thats not how it work.
I have all the hardware to do the mod.
  • 2 years later...
  • 2 years later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
