just made this mod to my car & it has made a difference to the cooling of the a/c, i dont know how many degrees it has dropped BUT i can most certainly feel the drop in temp :P thanks cubes :D
  • 7 months later...
tried this mod and it works like a charm but i decided to change the pressure switch ($73 and plus gas$50) and make the fan auto. but anyhow thanks very much for sharing it with us and 10 out of 10 for instructions.
  • 4 weeks later...
took me a while, but I finally got around to it ;)
just to confirm for others. on R33 its the pin on the far left (driver's side) on both relays. Same as cube's original instructions for R32.
I found this pic on the internet.
It does look identical so I'd say yes.. Its the 1N4004
i havent put a diode in yet. the one above is rated at 400V 1A. Is 1A ok for this application?
Edited by Munkyb0y
  • 4 weeks later...
ok, i've noticed something strange. r33.
if i turn my ignition on, but dont start the motor, then turn ignition off, my ignition lights stay lit.
after some poking around, i discovered if i disconnect this mod, and replace the relays as per standard, the problem goes away.
anyone else have this?
  • 1 month later...
Did this Mod on my R33 yesterday but will see how it goes this week.
it looked a little bit harder than the R32 pictures but once you move washer bottle and undo the power cables (unplug battery in boot first) it help get under the relay.
I spliced into wire 2 on each relay (under the relay it will list what pin 2 is and then where that pin plugs into I spliced into that wire which was the left one for both)
  • 11 months later...
  • 1 year later...
I don't think this can be done on a R34. The 'blower' fuse is located inside the cabin. Can someone with a R34 comment on this?
I did it to my r34 gtt but I used the relay to kick in my electric rad fan relay ( aftermarket fan which ive done to many r32s aswell)
QUESTION: Will the fan get "burnt out" slowly wear out if the fans are turned on at speed ( 80-200kms) or would the wind speed going 200k on a "track" be nowhere close to the electric fan speed??? note extra fan is mount horribly through the rad core
cheers
  • 8 months later...
  • 10 months later...
Would also like to know if this works with R34 GTR, as my aircon is slowly begins to get warm when stopped at a set of lights on an extremely hot day, and cools down again when i'm driving, and my water temps seem to go up when i'm idling at lights but slowly comes down when i'm moving.
  • 2 years later...
I know this is a bit old but I have found out a much simpler way to have the Rad fan kick on then messing with the relay box and installing a diode.
very simple,
all you need to do is jump the over heat switch.
(This is a test jumper, I have an old temp switch I'll chop and solder as a jumper)
Fan will only kick on when you turn on the A/C.
this fan will only operate with the A/C system engaged.
With the A/C off it will not turn on if the engine runs hot, if it did the fan would always be on when the jumper is installed.
Best part is you can revert back within seconds
Edited by Nissan_Junky
  • Like 1
  • 2 months later...
Whats up guys. So I have been trying to figure some stuff out before I do this mod. I know this thread is very old but maybe the GTR gods can help me out. From my understanding the aux fan comes when temps go over 90c. Does the fan come on only when the aircon is on or does it come on any time the engine goes over 90c regardless. I ask because my fan comes on without a problem when the aircon is on and it goes over 90c but it does not come on with the aircon is off. The service manual under the coolant section says to jump the plug just like the user before me did but it only comes on instantly if the aircon is on.
I think I am having issue with the aux fan coming on independent from the aircon. I may be wrong so please correct me if thats not how it work.
I have all the hardware to do the mod.
  • 2 years later...
  • 2 years later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
