On 20/10/2022 at 12:03 PM, "G" said:
I meant I want it to work with the thermoswitch as the activator. So i don't have to push any buttons.
replace the existing thermoswitch with a lower temperature one?
That fan has nothing to do with the A/C, it's an overheat fan. Constantly referred to as the A/C Fan, A/C Condenser fan, etc.. when it's actually not.
It can be dual purposed to be one (like most have).
2 minutes ago, "G" said:
I'm pretty sure it won't activate if the ac is not on. Even if the thermo switch reaches 194 degrees.
You're incorrect :)
Please do not talk in F, it's a JDM and we are Australian.
We don't want another Mars Climate Orbiter disaster.
  • Haha 2
8 minutes ago, "G" said:
Nope, it won't activate alone.
If so, someone has cocked about with your wiring.
The above diagram is from a Nissan Manual, you're telling me they decided to print the wrong information and wire it differently?
  • Like 1
I deleted my air con, everything under the hood. Now it won't activate at all. I want to create a stand alone circuit that activates the fan at 194d.
it has nothing to do with the A/C, the overheat fan is on its own circuit.
  • Like 1
Then as Dose Pipe said your wiring has been stuffed with unless your ECU is not factory, as the fan has its own individual relay.
On the factory ECU the fan relay pin is always grounded, so if you bridge / bypass the radiator thermo switch you energise the thermo fan relay turning the fan on.
I will point out that the relay activation ECU pin is not constantly grounded on full stand alone ECUs like Haltech, Link etc. as they rely on the logic parameters to ground the input. In the case of a Power fc D-jetro map sensor vesion this pin is completely made redundant so the fan will never turn on.
  • Like 1
24 minutes ago, GTSBoy said:
Actually the above diagram is from MSPaint. I took the snip from the original diagram from the manual, pulled out the ECU connections and made it generic for an arbitrary fused power supply, relay, thermoswitch and main load.
I don't see your diagram.
Manual states 90c +/- 3c just so we are not talking Fahrenheit rubbish.
  • Like 1
mines ecu.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
