200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension
  • Replies 148
Posted Images
^ will this be addressed in future kits?
Nope, we haven't found that the brackets are necessary on the Road and Track kit, as most guys doing track work have changed to braided hoses all the way to the calliper. The brackets are there on the Road Kit of course.
:D cheers :D
A few comments;
Coil overs can't fix suspension geometry problems when you lower a 200SX too far. Hence it doesn't matter what brand of coil over over you use, anything below the recomended heights will most certainly result in geometry issues. Stick to a sensible height and you will have a great handling vehicle with good ride comfort.
The "metallic noise" previously mentioned was a loose sub woofer crashing around in the boot and the spare wheel well, which had no spare wheel in it.
The bump stops are 80 mm when untrimmed. The trimming ratio is not 1 to 1, we need to have more bump stop available to absorb the impact the lower the chassis is. Otherwise there is potential for the shock to bottom out. The theory (of 1 to 1) means that 80 mm lowering = zero bump stop, which is pretty silly. Obviously we use a ratio for bump stop trimming that is less than 1 to 1.
I have spoken to Chris at Centreline and he is happy that there are no issues with the kit as supplied.
:D cheers :D
Well, not exactly. My rear is 355mm now and there's still a pretty loud metallic noise when going over hard/high bumps.
Then for the fronts, which is 355mm at the moment, occasionally, I get a little creaking when steering is under stress. Or when going over undulated road surfaces.
Other than that, at the ride height, it's fantastic! :D
Edited by eron
Other than that, at the ride height, it's fantastic! :sick:
Have you taken it back to Chris to check? Last time he spoke to me, he said it was OK.
:dry: cheers :sick:
+1 to Gary aka Sydneykid he has been very helpful throughout the whole process was a slightly longer wait then expected but deffinately worth it car feels amazing. Haven't had a good chance to try it out at its limit but definitely very happy with this product.
Thanks for all your understanding and help Gary!
-Peak
it's already done.
read my review if you want.
Gary if you believe i'm too critical please ask me to revise it. I honestly appreciated your work.
http://www.nissansilvia.com/forums/index.p...60#entry3427886
Sorry for the delay in responding, especially to PM's. The video card in my home PC died and it took me 4 days to find out what it was and fix it. So I am about 110 PM's behind at the moment and trying hard to catch up. Add that to the workload at Superior Suspension (12 to 14 hours a day, 6 days a week) and it will take me a few days to answer everyone.
Hang in there, if you have transferred money, it's safe, I am not going to run off to Brazil with it. You won't miiss out, the Group Buy isn't going to end soon as I have spent some time with Bilstein securing the shock supply for a couple of months at least.
Advanced warning, I am off to the US for 5 weeks from 1st October to 5th November. Checking out some east coast action, Detroit, Chicago, Daytona and the SEMA show in Vegas. So when I don't respond to PM's or emails in that period, I am sure you will understand why.
>_< cheers :D
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
