200sx S15 Bilstein, Whiteline, Eibach & Noltec Suspension
  • Replies 148
Posted Images
^ will this be addressed in future kits?
Nope, we haven't found that the brackets are necessary on the Road and Track kit, as most guys doing track work have changed to braided hoses all the way to the calliper. The brackets are there on the Road Kit of course.
:D cheers :D
A few comments;
Coil overs can't fix suspension geometry problems when you lower a 200SX too far. Hence it doesn't matter what brand of coil over over you use, anything below the recomended heights will most certainly result in geometry issues. Stick to a sensible height and you will have a great handling vehicle with good ride comfort.
The "metallic noise" previously mentioned was a loose sub woofer crashing around in the boot and the spare wheel well, which had no spare wheel in it.
The bump stops are 80 mm when untrimmed. The trimming ratio is not 1 to 1, we need to have more bump stop available to absorb the impact the lower the chassis is. Otherwise there is potential for the shock to bottom out. The theory (of 1 to 1) means that 80 mm lowering = zero bump stop, which is pretty silly. Obviously we use a ratio for bump stop trimming that is less than 1 to 1.
I have spoken to Chris at Centreline and he is happy that there are no issues with the kit as supplied.
:D cheers :D
Well, not exactly. My rear is 355mm now and there's still a pretty loud metallic noise when going over hard/high bumps.
Then for the fronts, which is 355mm at the moment, occasionally, I get a little creaking when steering is under stress. Or when going over undulated road surfaces.
Other than that, at the ride height, it's fantastic! :D
Edited by eron
Other than that, at the ride height, it's fantastic! :sick:
Have you taken it back to Chris to check? Last time he spoke to me, he said it was OK.
:dry: cheers :sick:
+1 to Gary aka Sydneykid he has been very helpful throughout the whole process was a slightly longer wait then expected but deffinately worth it car feels amazing. Haven't had a good chance to try it out at its limit but definitely very happy with this product.
Thanks for all your understanding and help Gary!
-Peak
it's already done.
read my review if you want.
Gary if you believe i'm too critical please ask me to revise it. I honestly appreciated your work.
http://www.nissansilvia.com/forums/index.p...60#entry3427886
Sorry for the delay in responding, especially to PM's. The video card in my home PC died and it took me 4 days to find out what it was and fix it. So I am about 110 PM's behind at the moment and trying hard to catch up. Add that to the workload at Superior Suspension (12 to 14 hours a day, 6 days a week) and it will take me a few days to answer everyone.
Hang in there, if you have transferred money, it's safe, I am not going to run off to Brazil with it. You won't miiss out, the Group Buy isn't going to end soon as I have spent some time with Bilstein securing the shock supply for a couple of months at least.
Advanced warning, I am off to the US for 5 weeks from 1st October to 5th November. Checking out some east coast action, Detroit, Chicago, Daytona and the SEMA show in Vegas. So when I don't respond to PM's or emails in that period, I am sure you will understand why.
>_< cheers :D
Guest
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
