hey, can anyone help out basically i got a Bosch 023 and a set of splitfire coils installed yesterday and on around 14psi it feels like the car loses all fuel and just comes to an almight halt but this is only when im giving it some which leads me to believe the stock ecu is limiting the fuel. is this true? i dropped it back down to around 9psi and its only happening at the higher end.
can anyone share some light on this situation? also if the car needs a tune would a safc solve this problem?
sorry if i sound stoopid and habibish i dont mean too but i seriously have no clue what it could be :S
:yes:
https://www.sau.com.au/forums/topic/153420-fuel-cut-at-4000rpm/
Sounds like rich & retard if you've backed off the boost and its pretty much ok.
Do a search with: +rich +retard
It will answer all your questions, and cover all the other possibilities.
Oh, and i wouldnt be running 14psi through the stock turbo for too long either.
oh ok. kool that sounds alrite, so a tune will have it in order.what is causing it thou is it the stock ecu cutting the fuel like i thought? the sudden jolt is strong enough to throw me out the front window if dont hvae my seatbelt buckled.
its just one thing after another with these cars, all good fun thou.
Edited by NicsR33
can't tune a factory ecu amte. Need a powerfc or something tunable.
14psi wil kill a stock turbo, intercooler no good for over 10psi, and fuel pump needs to be changed.
Anything 12psi and over = rich and retard... You'll lose about 40rwkw like this.
A mates R33 had the same issue some years ago.
He had boost pushed up to 14psi and on the dyno it was fuel cutting. i.e simply cutting all power as in nothing, zilch acceleration.
The same as the R32 GTST's do at around 16-17psi. Well mine used to.
cheers for the reply. when i meant ill get the car tuned i meant with a PwrFC i was just checking out different options.
the sparks are new, they are the NGK Iridium or something i think they come pre-gapped at .8mm. fuel filter and pump are both new all this was done only 500km ago (got the major 100k service done early). i got a feeling its just a tune cause im getting shit house economy with the car too so yeh might just be that.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
