In the market for a 1995 model r33 in brisbane around the 15k mark. Must be manual, colour doesn't mean much as long as it's clean and good condition. If anyone wants to make a quick sale send me a pm with description please as I'm looking at buying in the next week or two.
Steven.
https://www.sau.com.au/forums/topic/153434-wtb-manual-r33-gts-t/
yeah ive actually been looking on there for the last couple of months but haven't seen anything that's jumped out me. I figured posting on a skyline enthusiast site would be better and so far it is. Thankyou for your input though it's much appreciated :blink:
late 95 r33 gtst series 1.5 with factory high wing and different grille silver in colour very good condition full stainless ces racing splt dump turbo back exhaust $worth about $1700 from memory?) decent stereo with mp3 and supb and amp boot is boxed in for this about 75000km lowered suspension and timing belt and idler and tensioner have already been done aswlel as major service 17x8 and 9 inch ssr lightweight wheels great car in general and good condition no problems looking at $16000 with rwc and remaining rego without the plates!!
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
