  • Replies 166
Posted Images
I'm at the gabba - for those who don't know where we are goin I can meet at Milton Maccas prior and head Nth from there...
Note: Only suggestion at this stage - depending on replies obviously
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2881216
i'm gonna be drivin up that ways, i can meet up
ian i'll have a meatlovers and a hawaiian
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2882066
you know you want to :bomb_ie:
Ground rules have been added to the first post. The usual, dont be a dickhead rules. None of you should have to read them, if you think what your doing might require you to review the rules I ask you to look at the spirit of the rules and the cruise, not the letter.
Most importantly however is stay off peoples tails. Id like to see at least 1.5 seconds between each car, there will be alot of cars up there and alot of drivers that are unknowens, at least to me. Anyone found to be being a problem will be cautioned once, then they will be asked to go home. I dont want to see a repeat of the december run's bad apples. Stoned ute drivers and mad-skid 200's.... :sleep:
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2882200
Ian,
what time are you likely to leave the Waterworks road BP?
I have to go to the hillclimb briefing on Friday night at 7pm - going to try the Mt Cotton hillclimb on Sunday.
Might all get to hard to come on the cruise, as I want to change my oil sometime between Friday night and Sunday morning (track day last Friday).
cheers
Mike
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2884363
I can push it back a little if you would like, probably leave the BP at 7:30 - 7:45? there will be the usual stuffing around at the first meet up point, people will be late, etc etc. If you can get to the bp on waterworks road by 7:45 we will be there. If your running late just push it up nebo, by the sounds of things your pretty quick and the route has been posted, you could prob catch up by jollies.
Konrad, do what azzurra says :laugh:
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2884377
For thoes of you who are going to be late:
Please ring me ON THE NIGHT and let me know, or SMS me ON THE NIGHT. We will be leaving once the last person rocks up or at 7:30 from the bunnings, then 7:45 from the BP. After that your next chance of catching us is at jollies... There are few stops after jollies for a while, but if you dont get to us then make sure you have a coppy of my dodgy-directions.
My number is 0400 813 419
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2885760
Nah i've gotta leave straight after work at 4pm so i'll be passing thru maryborough about the same time as that pizza is passin thru your systems lol :laugh:
Wish i could go tho :( i want to see pics when i get back!
https://www.sau.com.au/forums/topic/153441-closed/page/6/#findComment-2885848
Guest
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
